Previous in Forum: Cold Forming   Next in Forum: Help Needed: Ganged Rheostat
8 comments
Friend of CR4
Water Leakage Detection Equipment
02/17/2006 10:12 AM
dawne correia writes:
I am looking for the equipment that can pick up a leaking water line in a wall or the ground. It has a screen that shows you the different colours according to the temperature (e.g. water) would be one colour and the earth another in so detects the leak or broken line. We are losing 2000 gallons of water per day and can not find the leak. No physical signs and are worried the it is not under minding our house could you please advise us on the equipment we need.
Thank you!
Off to take on other challenges. Good luck everybody! See you around the Interwebs.
Water Detection equipment
02/17/2006 9:47 PM
I have not checked for it, but if anyone has the equipment you are seeking it will surely be Time Motion Tools at www.timemotiontools.com
Re:Water Detection equipment
02/17/2006 9:53 PM
TMT-03-1000520 look up the preceeding item at www.timemotiontools.com It may provide considerable input for your problem.
Finding the source of the leak
02/18/2006 6:47 AM
If the leak is in a hot water system, thermal imaging would be a great way of detecting it, however if it is not the best way of finding the source. I would reccomend using acoustic detection where the sound profile can detect the source of the leak up to 10ft below ground, it can detedt with an accuracy of a few centimeters.(availiable for hire from ashead technologies, and other) If the pipes are buried deeper i would reccomend using tracer gas.
Re:Finding the source of the leak
02/20/2006 10:20 AM
I agree. If the water is not showing up at some location that would provide us some evidence of where the leak is, then we always call a company that offers sound detection capabilities with a trained technician. It costs us about $300 each time. Some underground contractors purchased the sound equipment to own, but I believe having a trained technician eliminates many of the "false" detections. Good Luck.
leak
02/18/2006 9:36 PM
Look for a wet spot that stays wet 24/7 or try a DYE pack, non lethal dye of course, to find the leak. I found it cheaper in one instance to replace the pipe from the meter to the home instead of tracing down a leak.
Re:leak
02/18/2006 9:43 PM
E-mail to Dick Olson at slocuda@charter.net or goco@utech.net
Good Answers: 18
Water leak
02/20/2006 7:40 AM
How much cheaper would it be to replace the underground water pipe than to buy detection equipment?
Water leakage
02/22/2006 11:53 AM
I think the suggestions given by various person are right but are not suitable for your level ,as they are costly. You should consult your plumber and ask him to check any malfunctioning of valves such as nonreturn valve which controls you tap supply which conects your residence's line with main sourcing line .
Register to Reply 8 comments
Anand (1); Anonymous Poster (3); BigSimon (1); Bill (1); ccoop610 (1); dadw5boys (1)
