Previous in Forum: Greenhouse Fan and Vent System   Next in Forum: Celebrating the Eiffel Tower
Friend of CR4
Help Needed: Roofing a Terrace
02/21/2006 10:58 AM
Bhakti parab writes:
We own a bunglow with a flat slab. Since we visit very rarely the place, the bunglow is normally closed. This has very badly effected the terrace and the inner walls of the structure. It leaks a lot in the middle of the hall from the terrace...
We have tried number of things to solve the problem, but to no avail. Finally we decided to construct at a specific height and roof it... If I can get a feed back we can try that before roofing the terrace...
Could anyone suggest products that are available in market?
Thank You!
Off to take on other challenges. Good luck everybody! See you around the Interwebs.
leaks
02/22/2006 12:14 AM
I own several buildings on slabs. mouisture is a real problem if you have no basement or crawl space under a house. Moisture builds up inside fast and takes a lot to get it out. Finding the true entrance for water can be hard. Often it is better to start tearing out where the water damage is and follow the damage to the entrance.
Location: Colville up the top of the coromandel peninsula
water content in closed housing.
02/22/2006 8:22 AM
In my experience of housing I can make two suggestions. As you say that the water collection is prevalent in the hall-way I'm assuming that the hall-way is located in the interior of the buildings with flat concrete flooring. And secondly I am assuming that you are referring to dampness to such an extent that it could be called leakage, such as is possible through concrete structures. realisations with types of housing construction: I would like to ask weather the building are constructed with aluminium joinery, such as windows and door frames, sliding door and the like? These building methods seal the building from the normal breathing that a building constructed from wooden joinery does and therefore makes the building susceptible to condensation areas within it's structure and it would therefore become necessary to use "dehumidifiers" constantly to compensate for the heat exchanges from night temperatures to day temperatures which cause the condensation of the building that lacks breathing materials within it's structure especially concrete floored, walled or roofed buildings. These same problems are rectified by making the "flooring with built in hot water piping" running through them as my sister has in the past buildings. I imagine that your buildings would suffer from condensation more than leakage persay, as leakage refers more to a hole in the structure than anything else and condensation can amount to a greater quantity than one would expect. If in fact there is an underground water seepage I would suspect that it would be isolated to only one particular property and not on several properties as you wrote.
Thankyou and always - -accentuate the positive,when it's the positive you really need.
Roof
02/24/2006 8:28 PM
Roll Rubber works miracles on Flat pitches. If the water can't be shed you might try out smarting it and installing a drain pipe.
Location: on a silver spike on a hill in the center of a lake, it's a challenge, see if you can figure it out
Bungalow Roof
03/21/2006 11:02 PM
Built up roof system...with solid rubber membrane, goodyear makes the best product...no pun intended...the important thing with a concrete structure is to keep the water away from the foundation... all water to be shed at least 5 feet from footing...minimum...so to reiterate...sloped styrofoam roof pitched at least 1/4" per foot to a central drain which is to be drained away from foundation... the system works best when drain is central... find a good commercial roofer... for your bungalow it shouldnt run too much over $15.00 per square foot for material...the low tech choice...lots of tar in a can...
There are no problems, only solutions.......
Register to Reply 4 comments
Anonymous Poster (1); dadw5boys (1); mdbobbo (1); zzzgrinch (1)
You might be interested in: Roofing Materials, Roofing Services, Industrial Magnets
