Previous in Forum: finding latitude an longitude of a point   Next in Forum: contractor failed to fill all vertical rebar in block wall
Chart datum
11/23/2007 7:11 AM
PLEASE LET ME KNOW THE MEANING OF CHART DATUM IN HYDROGRAPHIC SURVEY WITH AN EXAMPLE
Pathfinder Tags: CD
Re: Chart datum
11/23/2007 8:52 AM
Usually, a chart datum would mean the reference level on a chart against which all other values are plotted. Without more context, it's difficult to say exactly what is meant here, but I guess it could refer to e.g. mean sea level(?).
The word 'datum' is the singular of the word 'data', but it is commonly used to describe a reference level, zero point, home position, fiducial value etc. etc.
Re: Chart datum
11/23/2007 3:44 PM
harinathreddy: Three posts with a similar theme in 2 days makes it look like you are having problems with homework and didn't take a serious interest in Trigonometry when you had the opportunity!
Re: Chart datum
11/24/2007 3:48 AM
The chart datum for tide tables is set a a level below which the equinox lows will not drop below for that location; from that datum the drafts of the tide are then referneced.
Try looking at wikipedia, british hydrographic office, or calcul de la maree
Re: Chart datum
11/28/2007 3:06 PM
There are numerous datums recognized in cartography. It is the reference point from which a reference grid originates and the subsequent grid itself in most instances.
Definitely a homework question. Now, do you trust me or do you go to the books like a good little researcher and verify/dismiss the findings?
Register to Reply 4 comments
Anonymous Poster (1); JohnDG (1); Stirling Stan (1); TexasCharley (1)
