Previous in Forum: Battery Powered Bathroom Fan   Next in Forum: Windmills and Bats
Friend of CR4
Scientists generate ball lightning in a lab
02/24/2006 10:00 AM
Eli Jerby and Vladimir Dikhtyar from the University of Tel Aviv in Israel created a laboratory version of ball lightning using a device referred to as a "microwave drill." The drill uses a 600-watt magnetron taken from a commercial microwave oven, which can direct microwave beams that bore through solid objects (and I thought putting a spoon in a microwave was cool!). Says Jerby of the experiment:
"Our experiment confirms to some extent the theory that ball lightning originates from hot spots in the ground created by normal lightning."
Check out these videos of their work:
Fire Column
Floating Fireball.
I'm trying to remember from my youth, is ball lightning the same thing as St. Elmo's Fire?
Off to take on other challenges. Good luck everybody! See you around the Interwebs.
