Doug Kerr writes:
I am looking for a battery powered fan to remove air from the bathroom through a pipe in the wall to an exterior vent. A switch is necessary. A timer-switch would be best.
Doug Kerr, Denver, Colo.
Try your local auto parts store, or go to Big Lots and find one of those cheap, little, "personal cooler" fans. I'd guess either would come with a built-in switch. If you use the type made for automobiles and trucks, you'll need a 12 volt battery to hook it to.
