I have several buildings with below grade water meter connected to the central UMCS. The problem is when the irrigation system is running, or it is raining, the meter pit fills up and shorts out the pulse sensor for the UMCS. Short of pulling the meters above grade and installing in the mech room, are there any suggestions on how to make the connections water tight?
