Previous in Forum: how to find out the weight of steel tanks ,the formula   Next in Forum: problem w/ t3604 e-machine w/ vista
motor hook up
11/26/2007 9:49 PM
I need to hook up a 3 phase motor to 480 volts 60 hz, the leads are U1 V1 W1 & U2 V2 W2 Do I tye the jumper bars across U2 V2 W2 or U1 to U2 ,V1 to V2, W1 to W2 ???
Safety - Hazmat - Environmental, Safety & Health Manager Hobbies - Musician - Theremin (That about says it all...)
Good Answers: 19
Re: motor hook up
11/27/2007 1:31 AM
Guest,
There isn't one answer to your question...
It really depends upon the way your 480 V is wired (3 or 4), as well as the specifics of the motor and its application (e.g., Delta or WYE connection, constant or variable torque, single or dual voltage).
Are there any clues to the hookup on the motor's nameplate?
You should open the peckerhead up, and see if you can trace which leads are "wire-nutted" together inside.
I'm slightly more familiar with NEMA; however in your instance:
IEC Nomenclature--6 (& 12) Leads:
Single Voltage WYE-Delta Connections
Mode - - - Conn. - - - L1 - - - L2 - - - L3 - - - Join
Start - - - WYE - - - U1 - - - V1 - - - W1 - - - U2&V2&W2
Run - - - Delta - - - U1,W2 - - - V1,U2 - - - W1,V2 - - - -------
Dual Voltage WYE-Delta Connections
Volt - - - Conn. - - - L1 - - - L2 - - - L3 - - - Join
High - - - WYE - - - U 1 - - - V1 - - - W1 - - - U2&V2&W2
Low - - - Delta - - - U1,W2 - - - V1,U2 - - - W1,V2 - - - -------
Constant Torque Connection
Speed - - - L1 - - - L2 - - - L3 - - - - - - - - -- - -- - -- - -Conn.
High - - - 2W - - - 2U - - - 2V - - - 1U&1V&1W--JOIN - - - 2 WYE
Low - - - 1U - - - 1V - - - 1W - - - 2U-2V-2W OPEN - - - 1 Delta
Variable Torque Connection
Speed - - - L1 - - - L2 - - - L3 - - - - - -- - -- - -- - -- - -Conn.
Low - - - 1U - - - 1V - - - 1W - - - 2U-2V-2W OPEN - - - 1 WYE
In closing, I'm NOT an electrician, so proceed at your own risk…
United States - Member - New Member Engineering Fields - Electrical Engineering - New Member
Re: motor hook up
11/28/2007 10:27 AM
Your motor should have a wiring nameplate showing you connection diagrams. I suggest you use that instead of asking out of the blue. Wiring motors is not a standard.
“There's a sucker born every minute, and I happen to be one of them”
Re: motor hook up
11/28/2007 8:56 PM
Hi Guest,
These letters are the 'new' DIN 42401 standard.The windings are U1-U2,V1-V2,and W1-W2
Just check that there is continuity U1-U2, V1-V2, W1-W2,and that there is no continuity between U1-V1, U1-W1, V1-W1.If there is any discrepancy stop,you've got an oddball.
For star connection which is probably the one for 480V join U2-V2-W2 together and connect the power wires to U1,V1,W1.
Most motors are wound for dual voltage in Europe around 240/400v,the 400v connection being as above and the 240v connection is W2-U1, U2-V1, V2-W1 which is the delta connection,power wires going to the joined windings,i.e. to W2-U1 junction,U2-V1 junction,V2-W1 junction.
Its very unusual to find small motors connected in other than star for the voltage you have.
Re: motor hook up
04/24/2023 11:28 AM
Is contacting the manufacturer out of the question for some reason?
oldeng (1); PWSlack (1); T Man (1); The JMAN (1)
You might be interested in: Hook and Loop Fasteners, Tie Down Straps, Hooks
