Omron Programmable Relays ZEN-10C4 - Need Support Software
12/02/2007 3:12 PM
Hello Sir,
I have one Omron Programmable Relays ZEN-10C4 Series but my support software cd braked. now i have only trail version of its which date is finish so what i can do here ?
TARGET - Where many stop thinking, some start from there. Tenacity to get target helps to WIN.
Re: Omron Programmable Relays ZEN-10C4 - Need Support Software
12/02/2007 6:11 PM
Remove the pertinent entries from your computer's registry and reload the trial software
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore all progress depends on the unreasonable man" George Shaw
12/02/2007 9:17 PM
You should be able to send the defective disk back to the manufacture for replacement.Until you can do this you can try removing the registry entry's,if you have never done this before there is a good chance of crashing the computer.click start then run enter regedit next under registry click export then save a copy of your registry.under edit click find,enter the name of your software ,click find next ,delete the keys repete until you reach the bottom of the tree.note this may also cause problems with other programs so don't do this unless your ready to reload the computer.
12/03/2007 11:07 AM
If the trial period has expired you can quite often simply change the date on your computer back to within that period and it will work. I have found a couple of trial programs that set a registry flag on time expiration but that was simple...change the date...then the flag
Speed doesn't kill. Sudden stops, brick walls, and old ladies in Buicks do.
