Previous in Forum: electro-tinning   Next in Forum: ASTM Standard for Rapid Prototyping
Machinery for Potting Ceramic Material
12/03/2007 4:38 AM
Hello, I am a student at university in Mechanical Engineering.I have got a big question If any one can answer me I would be thankful to them.
Q: How to realize a machine for potting a ceramic material which is to be premixed with say water and fill into a 6mm dia tube with 15 mm length? The premixed material cannot be used more than 15 mins. Can I find a machine which has a supply of powder one side, from other side water and mixes in a injector for the required amount to fill the tubes and injects into the tube without any air bubbles? The process should be fully automatic with a control unit. Important point to be noted is this ceramic mixture gets hardened within 20 mins so should be careful that the mixer in the injector should be refiiled or with the help of a control unit takes little amount of powder and water (ratio 100(powder) : 13(water)) mixes in the injector with the help of a rotating tube inside the injector which moves with the help of a rotor.
Re: Machinery for Potting Ceramic Material
12/04/2007 5:58 AM
Search for "static mixer"
It might solve your problem.
12/05/2007 5:18 AM
Can you please explain more in detail while I am not looking just a machine but an fully automatic machine which works faster without any manual hadling. It should automatically feed the powder as well as water mix it and inject it . As I told important point in this process is u can use a paste more than 20 mins as it is impossible to inject.
12/06/2007 2:33 PM
Search fon Goolge for An Automatic Static Mixer that can do whatever you want,
I think I bought one a few years ago, works great
12/10/2007 10:14 AM
This is not a best solution to find a static rotor, as my problem is not just to mix but also to inject and well Searching in goolge is done before I post it but still thanks for the suggestion. But I this is not a good solution for my problem either you didnot understand my problem completely or u suggetsed me half solution
12/10/2007 10:14 AM
This is not a best solution to find a static rotor, as my problem is not just to mix but also to inject and well Searching in goolge is done before I post it but still thanks for the suggestion. But I this is not a good solution for my problem either you didnot understand my problem completely or u suggetsed me half solution.
