Previous in Forum: What is the Industrial Standard Actuated Valve Control Method?   Next in Forum: Open Source Technologies
10 comments
Converting Water to Steam
12/04/2007 11:15 AM
How much heat is needed to conver 290 g. of water from 22 degree Celsius to steam at 300 degree Celsius?
Good Answers: 66
Re: physics
12/04/2007 11:31 AM
Sounds like homework; what do you know about specific heat?
Aequam memento rebus in arduis servare mentem.
Engineering Fields - Mechanical Engineering - By Degree Engineering Fields - Manufacturing Engineering - By Profession Popular Science - Weaponology - By Interest United States - Member - Member Since My Inception
Re: physics
12/04/2007 1:01 PM
Sounds like homework. You need to dig into the books to find the solution and have your own "Ah ha" moment...
Light travels faster than sound. That's why some people appear bright until you hear them speak.
Re: Converting Water to Steam
12/05/2007 2:28 PM
When I was in school, I wouldn't have even considered asking strangers for help on something this basic...whatever textbook you are using will have the formula in bold somewhere in the chapter. All I'll say is remember the phase change, as well as the temperature change.
12/05/2007 2:45 PM
first get the amount of energy you need to get 22 degree water to 300 degree senable heat. mc delt T
then convert that water to steam at 300 degree, latent heat
calculate, add the two
bish bash bosh
homework done
Good Answers: 18
12/05/2007 5:52 PM
Alternatively, just use the Steam Tables and multiply by the weight of water.
12/05/2007 11:26 PM
Assuming the water is at sea level and ready to boil ( 100° C ), it should take 62.27 btu's to convert the .0639334 lbs. (or 10.23 oz.) of water to 100°C steam, then another 12.03 btu's to reach 300° C.
974 btu/#/°F for latent conversion then .48 btu/#/°F for steam.
Note: ice is .46 btu/#/°F
raising water temperature is 1 btu/#/°F
changing ice to water is 144 btu/#/°F
Unless you're the lead dog on the sled, the view is always the same....
12/06/2007 2:05 AM
Look in the steam tables the relative enthalpies of both.Multiply the difference by the quantity (the enthalpies are given per unit weight).
12/10/2007 6:36 AM
→ Steam tables.
Look it up there.
Italy - Member - New Member
12/14/2007 3:04 PM
Nobody asked our guest for following basic: at which pressure would the vaporization process take place? Final result is different, if pressure is 1, or 5, or 20 bar, and so on.
12/16/2007 11:21 AM
I suggest that you find a general chemistry college text book and make the calculations for yourself.Only then will you have a good understanding of the answer.
agua_doc (1); All About M.E. (1); Anonymous Poster (2); BorgoPio (1); CSM Engineer (1); inventorman (1); meirb (1); PWSlack (1); Sniccus (1)
You might be interested in: Converting Services, Steamers and Steam Generators
