Previous in Forum: Front End and Back End Design   Next in Forum: Load Calculation of Motor and Gearbox
High Voltage Electromachinery: The Key to Absurdly High Power-to-Weight Ratios?
12/04/2007 7:10 PM
I've recently become very interested in designing efficient motors and alternators for use in a gas turbine hybrid electric vehicle. I feel that these designs may be able to achieve uniquely high power to weight ratios compared to the components in commercially available hybrid electric drivetrains due to the very high shaft speeds available from gas turbine engines. (thus compounding the advantages gas turbines may have over reciprocating engines in the next generation of hybrid vehicles)
These fast shaft speeds may facilitate very high voltages, which in turn could reduce the amount of windings and material required in such devices. I feel that a move away from the standard enameled copper winding paradigm to polymer insulation or more exotic designs could be the key to unlocking high voltage electric machines.
I am trying to source information and journals on the design of high voltage electric machines and dielectric breakdown mechanisms in such machines, but I haven't had much success.
Does anyone know of any journals that address this topic? A good book on alternator and motor design would be pretty handy as well.
Does this idea have any merit?
Good Answers: 19
Re: High Voltage Electromachinery: The Key to Absurdly High Power-to-Weight Rati
12/06/2007 3:34 AM
Gas turbine engines have a very high power-to-weight ratio, small size for a given power output, and less complexity than piston engines. Most of their other characteristics are negatives in an automotive application, viz. high exhaust temperature, low torque outside their optimum power range, noise, and a large appetite for fuel.
Many of the problems associated with automotive gas turbine power plants have been solved, largely by the Chrysler Corporation. The one remaining intractable is high fuel consumption.
Gas turbine powered locomotives were used by Union Pacific for several years, but went away when the market for their cheap residual fuel improved due to an expanding plastics industry. When they became uneconomic, they were retired from service.
Of course, this shouldn't discourage you from trying to improve other elements of hybrid vehicles. But unless you intend to develop a gas turbine with better fuel efficiency, you should probably investigate a different prime mover.
12/06/2007 7:36 AM
One option for your prime mover is the Starrotor, developed by a colleague of mine.
It has the thermodynamic efficient you seek, runs at higher shaft speeds than otto or diesel cycle engines, runs at slower shaft speeds than centrifugal or axial brayton cycle turbo machines. It is not quite ready for manufacturing but is getting close.
See www.starrotor.com
Good Answers: 21
Re: High Voltage Electromachinery: The Key to Absurdly High Power-to-Weight Ratios?
12/06/2007 7:42 AM
Higher speed is only going to serve to give you a higher frequency of whatever voltage you are designed for. The design of rotor and stator windings, excitation methods and levels, etc. will determine your voltage output. You may find yourself limited by design factors of other components between your turbine and the batteries regarding high speed and/or high voltage.
Try seeing what information is available through IEEE or its members.
Speed doesn't kill. Sudden stops, brick walls, and old ladies in Buicks do.
12/06/2007 9:37 AM
Hello,
when seeking superhigh power to weight ratios, once beyond the prime mover(s), you might want to look at Hydraulics. You will find some extraordiary power/weight ratios in fluid Power. Naturally, there are some potential negatives, but I suspect that you will need to employ fluid power to accomplish the optimum sizie objectives.
best wishes in your quest. One note: PLEASE advocate accessing OUR oil resources!
I will gladly provide additional information on request. If possible, please state desired output torques, speeds, size and weight objectives. The prime mover statistics would also be helpful.
regards,
John conwillow@aol.com
12/06/2007 7:15 PM
I was always under the impression that gas turbines offered higher thermal efficiencies than reciprocating power cycles (I think the atkinson is the most efficient)
http://en.wikipedia.org/wiki/Atkinson_cycle
My reasoning was that gas turbines offer much higher compression ratios (pinging/knocking/predetonation is not an issue). I also thought gas turbine engines have less friction than reciprocating engines. They're also much more tolerant to poor quality fuels, and so there are upstream energy gains in the crude refinement process, since gas turbine vehicles could run off low grade (low energy cost) hydrocarbons.
This is all speculation though, and I could be entirely incorrect.
As far as I know, shaft speed is related to frequency in synchronous machines, but it also could facilitate high voltages with less windings because field lines are cut quicker/at higher rates.
12/12/2007 6:04 AM
the efficiency of gas turbines drops as the shrink in size because of tip clearance losses and non-scalability of viscous effects. The advantage of fuel flexibility is nice though and I think is even more flexible than a diesel.
I believe that some european companies are going to voltages over 12v for cars in order to get higher energy density. It is just like cranking hydraulic pressure from 3000psi to six or 8 thousand PSI. I think what may limit this is safety concerns. Even for DC anything over 40 volts (42 volts?) needs covers and shield for safety reasons. and there would need tobe interlock and such to keep people from frying themselves, or cops and firemen at the scene of a crash, or the tow truck guy, or whatever.
In theory though the idea is sound. power is effort(voltage, pressure, force, torque) times flow (electrical current, fluid volumetric flow, velocity, rotational velocity)
cranking one up allows you to reduce the other and keep power constant.
Anonymous Poster (1); bubbapebi (1); jcrock (1); maniacal_engineer (1); parsec (1); Switchman (1)
