Previous in Forum: Bidirectionnal Interface Between 3V and 5V Buses   Next in Forum: Low-Noise Microwave Amplifier Design
India - Member - New Member
Laser Light Shows
12/05/2007 5:05 AM
how laser is used to produce images in thw show's. is it possible for us to design our own images using laser modules?
Pathfinder Tags: Laser
Re: Laser Light Shows
12/05/2007 10:25 AM
A typical way of doing laser light shows is with a set of x/y axis galvanic (or other type) mirrors. Basically, you point the laser at the mirrors. One mirror moves up and down, the other moves left and right, and with the combination you are able to aim the reflected laser light anywhere in a plane. Connect a computer to control the positioning of the mirrors and you can create any image you can imagine.
I got my master's degree doing this.
12/06/2007 1:25 AM
hello there, thanks for your reply. can you give me more informations like pictures or web links, or how should i search using google for the same topic.
my mail id is kumareshkj@gmail.com.
eagerly waiting for your reply.
regards
kj
12/06/2007 9:18 AM
There are many ways to control lasers and create Imagery, special effects.Using X-Y galvanometers, Acousto Optic Modulators, Acousto Optic Beam Deflectors, Poly Chromatic Acousto Optic Modulators, direct modulation of DPSS lasers for blanking and Intensity control, etc...
To learm more try visiting this site " www.laserfx.com " and go to backstage, explore every area.
Then try going to " www.photonlexicon.com " join the group and introduce yourself as a beginner, look around ask ?'s
12/06/2007 9:46 AM
Oh yes - I had forgotten about the acousto-optic modulator. I used it with an aperture to form a shutter.
Register to Reply 4 comments
bhankiii (2); kjkumaresh (1); Laserlover (1)
