Previous in Forum: U.S. Electronics in Australia: Will They Work?   Next in Forum: Laser Light Shows
France - Member - New Member
Bidirectionnal Interface Between 3V and 5V Buses
12/04/2007 3:34 PM
I am presently designing a few computer boards, for experiences, and need a simple way to interface a 5 volt data bus (indeed in NMOS, so nearer the LS-TTL than CMOS) to 3 volts level (for NAND EEPROM and 3V mixed devices).
Although the bus is specified at 20MHz, I shall at first work at 4MHz, so that slow devices are sufficient.
I have no previous experience with new fast logics such as LV TTL and so on.
nitrosamine
Engineering Fields - Electrical Engineering - New Member United States - Member - New Member
Re: Bidirectionnal Interface Between 3V and 5V Buses
12/05/2007 9:55 AM
There are a number of devices that allow level translation, one that we have used is this 16-bit TI part;
http://focus.ti.com/docs/prod/folders/print/sn74alvc164245.html
Your 20MHz bus should be no problem for todays logic devices.
Tom
