Previous in Forum: Expandable Material for Sealing / Gasket   Next in Forum: Curved Beams
Machining Complacent Materials
12/05/2007 3:51 PM
I need some help! I have a work about complacent materials, that are materials with lower or pour rigidity. The important is know how this materials are mechaning, what kind of methods are used and machines! I can´t find anything about this issue....
Sorry for my english:)
Thanks!
Good Answers: 66
Re: Machining Complacent Materials
12/05/2007 5:47 PM
I've had to produce some soft urethane parts to pretty tight tolerances and we always used grinding operations to finish the moulded parts. Used it on parts down to about 35 Shore A. Not sure how it would do on anything softer.
Aequam memento rebus in arduis servare mentem.
12/06/2007 1:05 PM
thank you for the answer! I would like to know how this operations are made! I don´t understand very well what are grinding operations! If you know some website about this send me the link!
thank you again:)
Good Answers: 66
12/06/2007 2:07 PM
Try this link...good luck.
12/12/2007 5:51 AM
sometimes you can freeze them and get a quick cut. pack them in dry ice (CO2) until they are cold soaked and then quickly clamp and cut. If it is something simple like a single slot on a mill, or an outside diameter on a lathe, then this is said (by a trusted co-worker) to work fairly well.
of course once it warms up .... so you have to work fast.
Register to Reply 4 comments
CSM Engineer (2); maniacal_engineer (1); Tangerina (1)
