Previous in Forum: Curved Beams   Next in Forum: How to Prepare a Large Propane Tank for Safe Oxyfuel Cutting?
United States - Member - New Member Engineering Fields - Chemical Engineering - New Member
PSV Location
12/05/2007 4:56 PM
I am looking at installing a PSV on a condensate line considering an over-pressure scenario due to an upstream valve failure. The line from the upstream valve to the next process unit is appx. 300 linear feet. Should I put the PSV as close to the high-pressure source (the control valve) as possible or can I put it anywhere? It seems obvious to me that it should be located close to the high-pressure source but I can't find a source that tells me this. Any ideas?
Money doesn't talk, it screams in your face.
Pathfinder Tags: relief valves
Good Answers: 19
Re: PSV Location
12/12/2007 4:50 AM
Should I put the PSV as close to the high-pressure source (the control valve) as possible or can I put it anywhere? You can put it at the end even.
