Previous in Forum: How Does a DVD Player Remember Where a DVD Stops?   Next in Forum: Calculating Busbar Ratings
Optoisolator Driver for Vaccum Solenoid
12/06/2007 4:08 AM
Hi to all!
I wish to know weather MOC3061 can drve the solenoid directly ( without using triac )or not.
The solenoid is operating on 230v AC and of 14 Watt.
I ahve read datasheet of moc3061 but can't find the output current capacity of it.
Anyone who can enlighten me?
Thanks on advance!
Re: Optoisolator driver for vaccum solenoid
12/06/2007 7:28 AM
hello!
are you limited to this specific component?
“For no man can forbid the spark nor tell whence it may come.” ? Francis Bacon
Re: Optoisolator Driver for Vaccum Solenoid
12/06/2007 10:46 PM
The data sheet tells you that this is a device to drive a Triac. It has a capability of short repetitive pulses (some 100usec with a compliance of up to 1A). But the total power dissipated in the triac area is 240mW, that means that if you connect a load to a 230 Vac through this triac, the current that passes will dissipate a power of 240milliwatt. Period. Your relay is 14 W or so. Why don't you connect a triac driver the way they show at the bottom of the data sheet?
Bridge rule #1: Nobody is as good as he thinks about himself nor as dumb, as his partner thinks...
Register to Reply 2 comments
