Previous in Forum: Selecting a Linear Stepper Motor   Next in Forum: What Is FEA?
Hot Gas Compression
12/06/2007 8:27 AM
I'm searching for a continuous process installation a compressor,
The gas to compress is constitued of :
N2 62% in mass,
CO2 26%
H2O 12%
The inlet flow is 4 000 cu.m/h
Inlet pressure 1 bar abs
Outlet pressure 2 bar abs
The main problem is that I want to compress hot gases (around 300 °C)...
Have you somme excellent ideas ?
Re: Hot Gas Compression
12/07/2007 11:05 PM
Your compressed gas will be approximately 873oC.
I'm not a compressor engineer, but that seems hot for most systems.
not much help
Brad
12/11/2007 3:31 AM
Please explain your calculation because, thanks to Mariotte, I've found 425 °C as outlet temperature...
PV=nRT and PVγ = Constant
Register to Reply 2 comments
You might be interested in: Bar Code Software, Bar Code Cards, Bar Code Scanners
