Previous in Forum: Autoreclose   Next in Forum: K Type Thermocouple
10 comments
Cable Cleats
09/15/2021 1:35 AM
Hi Everybody,
Can anybody advise what is the Minimum Cable Size at which Cable Cleats should be used.
In IEC 61914, Only testing requirements are mentioned there.
Pathfinder Tags: #CableCleats
Re: Cable Cleats
09/15/2021 5:16 AM
I think it has more to do with how the cable wires are run than size....
https://www.powerandcables.com/iec-61914-cable-cleats-short-circuit-protection/
Re: Cable Cleats
09/15/2021 6:13 AM
HI Solar for Reaching Out.
Yes, these are used to Tie Cables in Cable Trays.
But, i want to know at what cable should we use these.
Re: Cable Cleats
09/15/2021 7:16 AM
I think cable trays are used with light duty and ladder systems with heavier cable.... In any case you need something to hold the cables in place...
So it's the nature of the installation that dictates the use of cable cleat type and specification...
http://hugtherung.com/wp-content/uploads/FAQs_Rev_2015.09.11.pdf
https://www.oglaend-system.com/news/product-news/cable-ladders-versus-cable-trays-article34170-40065.html
Good Answers: 42
Re: Cable Cleats
09/15/2021 8:34 AM
From different cable cleat or clamp manufacturers the minimum cable diameter is 10 or 12 mm.
See for instance www.cmp-products.com cable cleat or id-Technik for cable clamps.
Julius
Re: Cable Cleats
09/15/2021 8:38 AM
Thanks for Reaching Out.
Re: Cable Cleats
09/15/2021 2:19 PM
They can be used on any cable size. You get various cleats to suit any cable diameter. And they can be plastic, metal, or wooden cleats. Is it for HV/MV or control cables?
Re: Cable Cleats
09/16/2021 2:39 AM
HI,
Thankyou for Adviding.
I am basically searching for the Minimum Cable on which we should use Cleats.
Re: Cable Cleats
09/16/2021 2:55 AM
All cable runs need to be secured or confined in movement, now whether that is a cleat or a wire tie or some other method, depends on the AHJ locally...absent that, just use some common sense....
Re: Cable Cleats
09/16/2021 3:48 AM
Mr. Abdullah. Simply put, there is NO Minimum. You can use cleats on 2mm2 if you wish or you can use cleats on 2000mm2 cables if you desire. It's that simple.
Re: Cable Cleats
09/20/2021 7:19 AM
The <...we...> will have been given cable specifications to work with. Simply select the smallest cable from the specification as regards sheath diameter, and the question is answered.
The specifications cannot be seen from here.
Register to Reply 10 comments
7anoter4 (1); IQ (2); Muhammad Abdullah (3); PWSlack (1); SolarEagle (3)
