Previous in Forum: Is it Possible to Remove the Mutation Changes from Junk DNA?   Next in Forum: Frequency Instruments to promote Resonant Healing
Popular Science - Weaponology - New Member Greece - Member - New Member
Philips HD11XE Power Supply Problem
10/08/2021 1:36 AM
Does any body have the electric diagram ( or know where my problem is )of the power supply of ultrasonic Philips HD11XE ? It does not have 5 and 12 volts ( the leds are blinking ) and after a while it shut down.
Thank you
athmio
Pathfinder Tags: philips power supply ultasonic
Re: philips HD11XE power supply problem
10/08/2021 2:21 AM
10/08/2021 3:06 AM
Yes. These people do. Give them a ring.
10/08/2021 5:01 AM
Can you post high resolution pictures of both sides of the power supply PCB?
How old is the unit?
Do any of the electrolytic capacitors look "distressed" (swollen, lifting off the PCB)? This is the most common cause of failure on old PSUs.
Can you see any evidence of overheated components: blackened burned components; darkened area of PCB etc.
Examine both sides of the PCB carefully even if there are no components on the bottom.
In desperation, if it's 5 and 12 volts, could you replace the whole PSU with a PC PSU?
Register to Reply 3 comments
PWSlack (1); Randall (1); SolarEagle (1)
