Previous in Forum: Remote Camera Operation   Next in Forum: Are fiber optic signals digital or analog?
19 comments
SMD CODE
11/06/2021 5:40 AM
we have facing a problem with a SMD code which L8C6A and L8BGA, pics are attached
we did not found exactly either this is BJT or MOSFET, and what is exact number is? please anyone can help me to find this two component..
thanks,
Munawer Hussain,
06-11-2021
Pathfinder Tags: smd code component
Re: SMD CODE
11/06/2021 11:10 AM
Re: SMD CODE
11/06/2021 1:44 PM
Re: SMD CODE
11/06/2021 10:39 PM
Try a tester...
Re: SMD CODE
11/06/2021 1:30 PM
Here is something you can try: Get an ohmmeter and measure between pairs of leads on the chip. If reversing the red and black probes results in a the same reading, the device is probably not a bipolar junction transistor (BJT).
Re: SMD CODE
11/06/2021 5:58 PM
They may very well not be transistors. From an index of SMD codes:
https://smd.yooneed.one/code4c38.html
"Due to the small size of most SMD components, manufacturers are not able to write the full part number on the case. They use instead a marking code typically composed of a combination of 2 or 3 letters or digits. When repairing an unknown electronic board, it becomes so difficult to know what is the exact type of a given component. This database allows to quickly find the part number of a SMD component when you have only the marking code."
Here are some codes starting with "L8B" and "L8C". Many are voltage regulators which are also 3 terminal devices.
L8B ADP3330ART-5 Analog Devices
SOT-23-6 Linear voltage regulator IC
LDO, 5.0V±0.7%, 200mA, -Shutdown, -Error
L8B IXD5108N18BGR IXYS
USP-4 Voltage detector IC
1.8V±2%, -Reset ODO, Cd
L8B IXD5108N18BMR IXYS
SOT-25 Voltage detector IC
L8B IXD5118C08BGR-G IXYS
0.8V±30mV, ±Reset PPO, Sense, hysteresis <1%, Cd
L8B IXD5118C08BMR-G IXYS
L8B S-1122B16MC-L8BTFG Seiko Instruments
SOT-23-5 Linear voltage regulator IC
LDO, 1.6V±1.0%, 150mA, +CE
L8B S-1122B16PN-L8BTFG Seiko Instruments
SON-5 Linear voltage regulator IC
L8B XC6108N18BGR Torex Semiconductor
L8B XC6108N18BMR Torex Semiconductor
L8B XC6118C08BGR-G Torex Semiconductor
L8B XC6118C08BMR-G Torex Semiconductor
L8B XC6129N17J7R-G Torex Semiconductor
USPN-4 Voltage detector IC
1.7V±0.8%, +Reset ODO, Det. Delay
L8C IXD5108N18CGR IXYS
1.8V±2%, Hysteresis, -Reset ODO
L8C IXD5108N18CMR IXYS
L8C IXD5118C08CGR-G IXYS
0.8V±30mV, ±Reset PPO, Sense, hysteresis 5%
L8C IXD5118C08CMR-G IXYS
L8C S-1122B17MC-L8CTFG Seiko Instruments
LDO, 1.7V±1.0%, 150mA, +CE
L8C S-1122B17PN-L8CTFG Seiko Instruments
L8C XC6108N18CGR Torex Semiconductor
L8C XC6108N18CMR Torex Semiconductor
L8C XC6118C08CGR-G Torex Semiconductor
L8C XC6118C08CMR-G Torex Semiconductor
L8C XC6129N19J7R-G Torex Semiconductor
1.9V±0.8%, +Reset ODO, Det. Delay
You might also try submitting a query:
https://smd.yooneed.one/contact.html
Re: SMD CODE
11/07/2021 1:29 AM
SMD transistor 69W WP9Y 23AL 52AP1 AHPB 72ABE SK S8C6A N21U L8C6A
...from link in #1
Re: SMD CODE
11/07/2021 1:06 AM
Re: SMD CODE
11/07/2021 4:53 AM
Here is a link you may find helpful.
https://www.sphere.bc.ca/download/smd-codebook.pdf
I was not able to find your numbers,but it may be useful in the future.The codes are constantly changing,and some are proprietary.
What type of a board are these used on?Manufacturer name?
Some companies I have dealt with erase all ID numbers from their chips to prevent knock offs.
They require off-board testing which is difficult with SMD's especially the really small ones,and a good component may be damaged during removal.
Re: SMD CODE
11/07/2021 4:54 AM
I see that the two devices are in the same position on two different PCBs. So it's reasonable to assume that they are essentially the same.
Also the two bottom legs connect across a large (polarised) capacitor, so a voltage regulator as per Rixter's post #4 makes sense.
Re: SMD CODE
11/07/2021 1:41 PM
Re: SMD CODE
11/07/2021 2:05 PM
Re: SMD CODE
11/07/2021 3:14 PM
I don't have a use for this and I still want one!
I used to build circuits back in the DIP days when I could breadboard them and then wire wrap once I got what I wanted. I can't even see SMDs, much less solder them...
Re: SMD CODE
11/07/2021 4:25 PM
Now for those shaky hands....
https://newatlas.com/high-tech-handrest/14444/
Re: SMD CODE
11/08/2021 8:35 AM
A quick note about the beginning of that first Youtube where he recommends some very sharp test probes.
I have always found that In circuit test fixture pogo probes are the best
Although they don't look very sharp here
The tips are actually shaped into four separate points
Incidentally the meter itself was bought before my last job which I was in for over thirty years, I've been retired for over three years now, and, the meter was the cheapest "shirt pocket" one I could find at the time. It uses a tiny voltages to measure resistance so that no PN junctions get forward biased when probing in circuit, so it has always been my go to meter for such tasks.
Re: SMD CODE
11/08/2021 9:56 AM
For very small soldering I made my own tips.I used copper wire of various gauges depending on the application.I once replace a SIM on a digital watch with a red LED display,Timex I believe if memory serves me right. The factory said I did not want to do it,but I insisted,and they sent me the chip,free of charge and wished me good luck. I used a 10X magnifying glass,and a not so small amount of Scotch. It was very tedious to say the least,and I would not try it again,especially now since my hands are not very steady,and my eyes are not that good. (The Scotch is still good though). The hardest part was preventing bridging of the pins.Used a lot of solder wick,and a quite a few 4 letter words. This was back around 1980,and I am sure they are even smaller now. For testing I use safety pins or straight pins. A safety pin can be inserted through the insulation of wires,and will stay put,or can be securely attached to a ground connection. I have an Old Fluke that has a diode test and resistance test,and conductance (nS) test.It is over 30 years old and still works fine,even though the display screen has it's share of age spots,just like me.
Re: SMD CODE
11/12/2021 12:26 PM
See a new thread I've posted. Note that at the end of the post I've said that when you can see clearly your hands seem to stop shaking nearly so much.
Good Answers: 11
Re: SMD CODE
11/07/2021 3:43 PM
I looked in The SMD Codebook:
The L8 device on the right may be a dual diode:
L8 BAT721A Phillips SOT23 dual common anode 40V 200mA Schottky
L8 BAR15-1 Siemens - dual PIN 100mA max
The 8B device on the left could be one of these Motorola (ON Semiconductor) parts:
8B MMBZ5227B Mot C SOT23 3.6V zener 0.225W
8B MUN2212 Mot N SOT23 npn dtr 22k+22k
8B MUN5212 Mot N SOT323 npn dtr 22k+22k
The last two devices are "digital transistors" with a 22K resistor in series with the base and another in parallel with the base-emitter junction. The SMD Codebook also lists a voltage regulator, but it's in a SOT89 case, so that one is not what we're looking at here.
Re: SMD CODE
11/08/2021 10:15 AM
Have you contacted the device manufacturer for documentation? I admit schematics and parts lists are a rarity outside of the authorized fabrication chain but one should still look for one.
Most electronics these days are not designed to be repaired primarily because of component failures cascading the electrical disaster to other areas. Also, just the cost of troubleshooting down to the component level often exceeds the price of a whole new device.
Good Answers: 25
Re: SMD CODE
11/18/2021 6:23 PM
The way they are connected tells me it is typical of a regulator with a protection diode or part of the switching of a buck converter circuit.
Register to Reply 19 comments
HiTekRedNek (2); kudukdweller9 (1); MNIce (1); Randall (3); redfred (1); Rixter (3); SolarEagle (8)
