Previous in Forum: The term RF "amplitude modulation" is a misnomer.   Next in Forum: Thermal overload relay
11 comments
Radar Question
12/26/2021 3:33 AM
I have a question for folks with radar experience. Is the frequency shift for a reflective target, the same as the frequency shift from an emitting target?
Re: Radar Question
12/26/2021 4:27 AM
Depends upon the type of RADAR. If it is a tracking or navigation RADAR the frequency is the same. If it is Doppler such as weather or traffic control, then the frequency will be altered by the speed of the object. For example if you have RADAR over land all you will see are hills trees buildings etc. Aircraft, cars, boats etc will all be masked by the surrounding background. Doppler RADAR eliminates that by displaying only objects that change frequency (moving). I recall a report of an object that only occasionally appeared on the screen. It turned out to be a flagpole moving in the wind
Re: Radar Question
12/26/2021 6:58 AM
The frequency shift from a reflecting target will be twice the shift from an emitting target, because the range to the latter is two way.
Re: Radar Question
12/26/2021 7:34 AM
Range of reflecting target is two way.
Re: Radar Question
12/26/2021 4:53 PM
OK, I think I understand, that if you are continuously tracking, one doesn't need frequency shift for target velocity. The velocity can be determined from successive plots.
And I was not aware that distance of target, in any way, effected shift????.
Let me ask the question in a different manner. My question is about the F shift.
Let me set up two scenarios.
No. 1. A reflective target is moving away from radar No. 1. There will be a red(decreasing F) shift, to the returning signal, in proportion the the receding velocity.
No. 2. Now attach a radar No. 2. to the target. Will the No. 2. radar signal, have the same frequency shift, as the radar No. 1. returning reflective signal?
Re: Radar Question
12/26/2021 6:05 PM
Oh, you're saying that the shift interaction of the reflection is two way, and additive, because the reflection has to turn around?
Pardon me.
Re: Radar Question
12/26/2021 10:12 PM
Let me try to explain a bit better...
Say the radar sends out a signal of 1 GHz, 1,000,000,000 cycle/sec, which has a wavelength of about 1 ft. If you are travelling toward this signal at a speed of 1 ft/sec, in 1 second you will see 1,000,000,001 cycles, the 1 billion transmitted plus the 1 you ran up on.
If you reflect these 1,000,000,001 cycles back, the radar receiver will receive 1,000,000,002 cycles, including the one extra cycle due to your motion.
In other words, the signal gets doppler shifted twice, once when it reaches the reflector and secondly, when it is received by the radar.
Engineering Fields - Aerospace Engineering - Retired South Africa - Member - The Rainbow-nation Engineering Fields - Engineering Physics - Relativity & Cosmology Popular Science - Cosmology - The Big Picture!
Good Answers: 69
Re: Radar Question
12/28/2021 12:55 AM
@Rixter wrote: "Say the radar sends out a signal of 1 GHz, 1,000,000,000 cycle/sec, which has a wavelength of about 1 ft. If you are travelling toward this signal at a speed of 1 ft/sec, in 1 second you will see 1,000,000,001 cycles, the 1 billion transmitted plus the 1 you ran up on.
If you reflect these 1,000,000,001 cycles back, the radar receiver will receive 1,000,000,002 cycles, including the one extra cycle due to your motion."
One should conceptually rather follow the relativistic thinking: in Doppler radar the only thing that matters is the relative speed (v) between the radar transceiver and the reflecting target. It does give the result that you calculated, but it comes about in a somewhat different way.
Fractional Doppler shift Δλ/λo= sqrt[(1+v2/c2)/(1-v2/c2)] ~ 2v/c when v is much smaller then c.
Good Answers: 69
Re: Radar Question
12/28/2021 1:56 AM
Oops, I have goofed the equation.
To avoid confusion, it should have been this one:
Δλ/λo= (1+v/c)/(1-v/c) - 1 ~ 2v/c when v is much smaller then c.
Re: Radar Question
12/27/2021 8:55 AM
This is a very bad way to explain it, but if you can see your way round the wrong parts it might help you see what's really happening.
Think of each "part" of the waveform as being an individual particle
If the whole wave form is moving at say v towards an object moving at u, then the approach speed is (v+u). When the "particles" are reflected they are moving apart at (v+u), and because the object is still moving at u the "particles" are moving back towards the transmitter at (v+2u). The frequency shift is doubled.
Re: Radar Question
12/27/2021 4:39 PM
Those are interesting examples. I prefer a moving line bouncing off a wall example. The movement of the surface, can change the length, of the reflected line. Due to the interaction time, or duration of the reflection.
It's interesting to note, that a reflection is an instant lossless change in the direction and momentum.(energy)
The frequency(energy) does not change with a stationary surface. And that a moving surface, can amplify energy.
It should not surprise anyone then, that emission could possibly be an instant event.
Let's replace the train whistle with a transceiver. And place another transceiver at the station.
With the whistle set up, we can put the whistle at the station, the the people on train, will experience to same shift, as the people at the station, when whistle is on train.
The audio Doppler shift is reciprocal. Because sound is continuous. The movement of the emitter, or the absorber, has the same effect.
Now, try it with radios. One radio is moving, one is stationary. Will the people on the train here the same shift as the people at the station? Will we get the same reciprocal effects?
Re: Radar Question
12/28/2021 3:31 PM
Reflection is pretty amazing. Being able to turn light, the frequency of light, the momentum of light and the density of light, 90 degrees(or even 180) in an instant.
Remarkable. No mass, no inertia, no time to turn. And it's only one turn, not an arc, or series of turns. Like moving mass has to be turned. Takes time.
Reflection....an instant event, or act, with(or having) a duration.
Emission....an instant act of propagation, of a duration? A chunk of EM disturbance. A series of intermittent chunks with a duty cycle. The chunk has duration(frequency), momentum, orientation, density. Just like we measure with light. The chunk is 1/2 period in duration. The other 1/2 period and the energy of it come from the absorber inertia, not the propagation. This happens in between chunks. That would make the power measurements of emitted RF off by 50%. Damn inertia. And measurement error. An effect of the measurement.
In any case, I think that a simple reflection, is a crack, in the curtain of nature. They don't come often. This crack, actually demonstrates absolute time. The propagation velocity, the reflector velocity and the reflection velocity, all use the same clock. Without absolute time, a moving reflection would not exist the way it does.
Register to Reply 11 comments
Haymaker (4); Jorrie (2); JWthetech (1); Randall (1); Rixter (3)
