Previous in Forum: Steam Drum PSV Inlet losses   Next in Forum: Continuously Cycling Double Cylinder Control
8 comments
Problems with a Briggs & Stratton Carburetor
01/04/2022 2:00 AM
I am trying to find the blue prints/ mechanical read out of a carburator that belongs on a:
Briggs and Stratton: 80232 made 1975
i am trying to clean it because the motor works just can't get the right gas to air ratio. and i think this is the first clean or overhaul this motor ever has had. Any specs, blue prints/ mechanical specs, read outs, or info on this motor would be helpful.
Thanks Engineering 360 Community.
5
Re: Problems with a Briggs and Stratton
01/04/2022 3:33 AM
01/05/2022 9:17 PM
Same engine that was on my mini-bike back in the seventies. I got to know it well.
01/07/2022 11:50 AM
Probably off topic here. But, I want to tell you, Brave Sir Robin, how much I appreciate your reliable and continuous input to this site. In the recent past I read some pretty obnoxious posts written in response to your posts. I want to counter those posts, because I appreciate your input.
01/04/2022 3:15 PM
Re: Problems with a Briggs & Stratton Carburetor
01/04/2022 6:12 PM
Nice relaxing video of complete lawnmower engine rebuild....
01/05/2022 4:43 AM
Strip it down and then clean all of it with carb and throttle body cleaner. Check out ebay and buy a rebuild kit, I just put a new diaphragm in one exactly the same on a rotary hoe and after a good clean and an adjust to the specs, did not need more than the diaphragm, in a B&S book I have but the same info is on the internet when you put your carb model number into the search.
Hare today, goon tomorrow!
01/07/2022 2:01 AM
Be careful with the fuel pickup tube as they are fragile. They can be bought off the internet or you could used a piece of tubing to connect across the break. The type shown in SE cutaway post is called a pulsajet carb.
01/07/2022 5:48 PM
I bought a particular lawnmower (push rather than ride-on) precisely because it had a Briggs and Stratton engine. When the time came to service it I found that the carburettor was a crummy plastic object, not in the least resembling the unit on my old cars, and was serviceable only by replacement with another crummy plastic unit. Not impressed.
Register to Reply 8 comments
Brave Sir Robin (1); ccoop609 (1); phph001 (1); SolarEagle (3); Stef (2)
