Previous in Forum: Measuring `State of Charge' of A Battery   Next in Forum: High Voltage
230V Flourescent Fixtures Needed
12/07/2007 9:27 AM
I am looking for some flourescent fixtures that can operate on 230V supply. I would like a short T8 style 12-18" long or a biaxial style of a similar length. I have done some looking, but without success. Can someone steer me towards a vendor?
Pathfinder Tags: flourescent
Good Answers: 61
Re: 230V Flourescent Fixtures Needed
12/07/2007 11:45 AM
Advance Transformer has a huge line of ballasts for many different bulbs & voltages.
12/07/2007 1:43 PM
Thanks pwr2thepeople, but what I really am after is a complete UL rated fixture. If I buy a transformer then I need to design the bulb holder, get it UL certified for my application, and I am looking for a shorter path from A to B.
Regards, Ron.
Good Answers: 230
12/08/2007 7:23 AM
Hello Rocket Ron,
If you advise your location, or where you need those fluorescent fittings, it would help to give you a nearby vendor.
Also advise how many fitting you are likely to need.
And of course, the mains frequency, thanks.
These are made in Australia, UK, New Zealand, (50 Hz of course), but perhaps that is not suitable or near your location
12/08/2007 11:14 AM
We are located in central Canada and we run on 60 Hz.
12/09/2007 4:57 AM
Hello Ron,
Most electrical suppliers will sell the connectors, ballasts, starters, separate! Many shop front displays use this method to light up a back lit display, using the frame as a base to screw the components to! Have you asked your local supplier if they do separate pieces!
Good Answers: 128
12/15/2007 8:43 PM
Sir,
I believe that most fixture manufacturers will be happy to quote you a modification. If they have a fixture which is the right dimension, style and tube then ask them to quote it with a ballast suitable for your input voltage. Since all components would be CU/L, a label for the entire fixture would be no problem. Depending on the quantity, the adder for the special order will vary.
JMM
Register to Reply 6 comments
jmueller (1); Mr. Truman Brain (1); pwr2thepeople (1); Rocket Ron (2); Sparkstation (1)
