Previous in Forum: Cummins power PCC technology and MCCB ?   Next in Forum: Current density v current supply and a generator size questions
13 comments
BUSBAR CALCULATIONS FOR MDB'S
12/09/2007 12:59 AM
Dear All,
I work as an Electrical engineer for an Automation Firm. Here i had encontered a situation where in the consultant had asked us to give them the SC calculation for the busbar of our MDB. When asked to our fabricator he gave me the following calculation (unfortunately) with out much explanation. Could somebody pls enlighten me on this:
As per the designed we had been asked to have a system that could withstand 50KA of SC current:
So formula (for calculating the area of cross section for a given SC current)
goes like this,
I = Area of cross section of busbar x 160A/mm2 x 0.8
where 160 is the current density of copper at 200deg Centigrade(as per the Nomogram table provided by the manufacturer).But the fabricator is not able to explain what that 0.8 factor is? Can somebody please explain:
Thanks in advance.
Pathfinder Tags: busbar calculations
Re: BUSBAR CALCULATIONS FOR MDB'S
12/09/2007 5:04 AM
You given the equation for current carriying capacity of busbar and not the SC Current.
SC Current is calculated by knowing the Fault MVA of the system connected to the Busbar. The factor 0.8 will be PF or any thumb rule factor
12/12/2007 2:36 AM
Could you please explain more on your statement since iam a novice. What is the difference between the SC calculation and a current withstand capability of busbar. I thought they were the same.My requirement is for the given the system, i have to check whether the busbar selected(for dimensions and material) is an optimum one.
Good Answers: 18
12/10/2007 11:34 AM
0.8 is a safety factor.
12/11/2007 6:37 AM
I agree with electrical@wonderla.com. The equation provided is for current carrying capacity of busbar and not the SC Current withstand rating. As to the 0.8 factor, it may be an uncertainty factor or temperature correction factor.
Calculating the short current withstand capability of busbar has to take into consideration the spacing between the bus bars and mechanical bracing of them.
12/11/2007 7:13 AM
dear friend ,
we are working in auotmated dairy compnay in Riyadh . we are using the siematic-7 &
PROFIBUS bus bar . pl porvide the basic knowledge about it . can u suugest the books which give basic knowledge .
any body can teaching siematic -7 & programing .
00966-566285854
nagarjun68@yahoo.com
regards
NAGARJUN
Good Answers: 42
12/13/2007 6:31 AM
Short Circuit current is calculated depending on the percentage Impedance and line voltage. Line voltage( V L ) is multiplied by 1.1 to take carte of the 10 % rise in voltage and Z .
As an example , In 3 phase 1000KVA Transformer ( single ), 22/ 0.415 kV,
the % Z = 5.25 and
Short Circuit Current
...... 1.1 x V L
I = -----------
......... √ 3 x Z
The Impedance Z should be calculated in ohms
........→ % Z x 10 x kV2
Z = ----------------- say in this case 0.009 (calculated)
............→ kVA
..................................→ 1.1 x 415
Short circuit current I = ----------------- = 29.3 kA
. ................................√3 x 0.009
The 0.8 given is a derating factor depending on the heat dispensing of the enclosure considering the panel is installed in indoor in well-ventilated room. .
12/15/2007 11:13 PM
Look at the Copper Development Association website - it has a book called "Copper for Busbars" for free with everything you need to know. This is the definitive reference.
07/25/2008 10:31 PM
Please provide a link to that book..
Thanks.
01/29/2009 6:48 AM
hi yaar
0.8 is noyhing but it is a derating factor.
04/07/2010 6:03 AM
.8 is the current per mm
05/09/2010 4:04 AM
it is the correction or derating factor
Correct me if i am wrong i am learner
05/22/2010 3:01 AM
ok Sir, This is for 50ka if required more then 50ka like 70ka and all then what is the factor
06/13/2011 10:15 AM
I = Size buss * 160/SQRT(TIME_breaker_OFF) => 1/SQRT(TIME_breaker_OFF) = 0.8
Register to Reply 13 comments
ALSTEF (1); Anonymous Poster (6); Bill (1); electrical@wonderla.com (1); ikhanuk (1); life 220 (1); V.I.Abraham (1)
