I have a piston that's about 0.0015in oversize and I don't want to bore the cylinder out. Can anyone tell me what is the best way to have the piston accurately downsized to suit the bore size and still retain the correct clearances all round? I thought about doing it with emery cloth/paper but not sure that that would be accurate enough. I'm concerned about maintaining the correct ovality. My measuring gear is limited to a vernier and feeler gages. Can regular machine shops grind/turn it down accurately? I'm doing a performance comparison between a coated piston and an uncoated piston on a single cylinder two stroke and it's a lot easier and cheaper if I can use the same cylinder to test both pistons.
