Previous in Forum: Rotary Vane Compressors - need links to sites with information plus view inside   Next in Forum: Brick-making machine
carbon move
12/09/2007 8:52 AM
Hello:
How can I move a Carbon from a drum or a bag to a tank. This is for to use the vessel as a filter vessel (GAC) so a TOC removal. Please ould you help me?
Popular Science - Weaponology - Cardio-7
Re: carbon move
12/10/2007 3:25 PM
Carbon move: Could you be a bit more detailed? Are you talking about moving a mass of activated charcoal? A carbon-based solvent? "A carbon" implies a carbon atom, which I doubt that you mean. What exactly do you want to transfer? What apparatus do you have for the transfer?
Good Answers: 101
Re: carbon move
12/10/2007 8:52 PM
Are you filling up a pressure vessel to make an activated carbon filter? If so, if the carbon is in small bags, you can simply pour it in through the access hatch a bit at a time. For large quantities, you can consider a screw conveyor or some similar material handling device.
Re: carbon move
12/11/2007 10:47 AM
Done it. Got the T-shirt. It's 'orrible! Personal experience of filling up 3 GAC filters each 3m3 from bags with a small scoop and a funnel resulted in a scooping time of about 10hrs. The washing machine took a pummelling that night, too.
Cardio07 (1); DVader1000 (1); PWSlack (1)
