Previous in Forum: Angular acceleration of pivoting assembly   Next in Forum: How to prevent rotation of the load pad of an inverted screw jack
Does a screw Jack induce transverse power
09/11/2022 10:25 PM
After installation of an anti-rotation key, will a screw jack induce transverse movement at the fixing point of the body of the screw jack?
Pathfinder Tags: screw jack
Re: Does a screw Jack induce transverse power
09/12/2022 11:07 AM
09/12/2022 11:09 AM
Make? Size? Manufacturer's instructions? Has it been tried?
Only, it's a little difficult to see the thing from here.
09/12/2022 12:37 PM
I believe the idea of the keyed design is to prevent any movement of the body of the jack...so hopefully not...
09/14/2022 11:14 PM
Do you mean from the load on the sloped helical screw? There would be a component trying to rotate the screw, but think of a worm drive--most are not reversible. Similarly, the load on a screw jack will not rotate the screw.
Lehman57
Register to Reply 4 comments
Anonymous Poster (1); Lehman57 (1); PWSlack (1); SolarEagle (1)
