Previous in Forum: How to prevent rotation of the load pad of an inverted screw jack   Next in Forum: Test bed for rowing machine
27 comments
Concentric coring of a solid bar
10/05/2022 7:18 AM
Is it possible to cut a 140mm dia solid bar into 2 part as this?
Re: Concentric coring of a solid bar
10/05/2022 9:46 AM
Yes.
10/05/2022 10:39 AM
By what means? Tell me please?
Any limitation for the length of the solid circular bar?
10/05/2022 11:01 AM
Method depends on type of material,and the precision needed.More info gives better feedback.
10/05/2022 11:04 AM
Yes, there will be limitations on the solid circular bar. Once again, it all depends on many things you are not telling us. For instance, what is the moisture content of this bar of cheese?
10/05/2022 11:29 AM
Depending on the length that you can drill, a wire electrical discharge machining (EDM) tool can do some pretty impressive machining.
https://www.globalspec.com/FeaturedProducts/Detail/EagleStainlessTubeandFabrication/329389/What_is_WIRE_EDM?fromSpotlight=1
https://www.kentusa.com/machine/edms/
My company happens to use the Charmilles brand machines.
https://www.edmnetwork.com/charmilles-edm-machines.asp
But I am not a machinist, so I cannot comment on the relative merits of various brands.
10/05/2022 11:44 AM
Yes, though it would be easier for the arrow to point to the left instead; all one would need is various sizes of hammer.
10/05/2022 11:45 AM
Isn't that how a punching tool works?
10/05/2022 1:24 PM
Did you say "Dancin Fool?"
10/05/2022 10:45 PM
Like totally, OMG, for sure . . .
10/05/2022 2:23 PM
The end product should be a pair of a shaft and a sleeve with 2-3mm gap.
10/06/2022 10:00 AM
Still, the mystery on length, service and material, at the very least. You should at least disambiguate between Swiss and Gouda....
11/09/2022 9:00 PM
The core drill would have to be very thin to do this,and you do not state the length of the bar.
Usually the max depth is limited to 6 times the hole diameter.
Is the gap the total difference in the diameters,OD/ID or the concentric gap when the rod is centered in the core?
I think it would be easier to make two separate parts for the precision you require.
10/05/2022 2:32 PM
10/05/2022 9:43 PM
These are some giant EDM machines...
10/05/2022 9:46 PM
But how well can EDM work on cheese?
10/05/2022 10:54 PM
As long as you set the current really low, it won't melt the cheese in the machining area and then you get a clean cut.
10/06/2022 10:52 AM
So one can use EDM to cut Camembert.
10/06/2022 4:14 PM
. . . and Venezuelan Beaver Cheese as well !!
10/06/2022 10:11 PM
I'll bet Leisure Suit Larry ate all of that runny morsel.
10/07/2022 9:47 AM
Can it do a Brazilian cut?
11/09/2022 9:05 PM
Sure..That is how they made this medallion.
10/07/2022 6:39 AM
Camembert is possible, but one must don the sacred cheese hat, not the cheese head, as has been widely reported by the liberal media...
10/06/2022 12:48 AM
I don't think it matters what you eat....within reason of course....
10/05/2022 7:20 PM
Yes, there are many sources that trepan bar into “pipe” with a core as the inside drop.
10/06/2022 9:57 AM
Trepan; really?
11/28/2022 2:44 PM
11/28/2022 10:13 PM
very clever machine!
Register to Reply 27 comments
Brave Sir Robin (4); HiTekRedNek (5); PWSlack (2); redfred (5); rwilliams (3); SolarEagle (4); Ti QE (1); truth is not a compromise (1); youngken (2)
