Previous in Forum: Chatting with GPT - Popcorn is served   Next in Forum: How Well Do We Understand Ourselves in Order to Teach a Machine?
Why a 'Language Model' (such as ChatGPT) is not even nearly AI
04/12/2023 8:16 PM
Walid Saba's point-of-view:
Pathfinder Tags: ChatGPT OpenAI AI
Re: Why a 'Language Model' (such as ChatGPT) is not even nearly AI
04/20/2023 11:24 AM
Here is an interesting alternative to the Artificial Neural Nets (ANNs) that are used with ChatGPT that models more closely how humans reason. It uses mathematical operations on 10,000 bit vectors.
https://www.quantamagazine.org/a-new-approach-to-computation-reimagines-artificial-intelligence-20230413/
04/25/2023 10:21 PM
"10,000 bit vectors" is merely numerical range to allow for higher resolution - of what?
The question at hand is on a principle level:
What could be defined as "Understanding" in reference to a machine, a man-made mechanism which can "Understand".
And even then, "Understanding" (or "Deduction" if you like) is barely the tip of the iceberg of traits required towards an ideal called "AI"
04/25/2023 9:58 PM
Register to Reply 3 comments
