Previous in Forum: I need a product under $20 to fix scratched dvd's, any suggestions?   Next in Forum: Algae in Outdoor pond
density
12/10/2007 10:10 PM
HI
does anyone here know any cost effective way of in line density measurement..(0.8-0.9) from my knowledge all existing commercial stuff look quite expensive..
Asoe
Pathfinder Tags: density
Re: density
12/11/2007 5:57 AM
Canada - Member - New Member
Good Answers: 11
Re: density
12/11/2007 11:19 PM
There are devices that comprise two static pressure sensors at a known distance/depth.
Might be difficult if you have turbulent flow.
You could use water columns for a cheap setup.
Re: density
12/12/2007 1:52 PM
I have seen where distillaries use a simple hydrometer floating in a pot to measure the density of the distallate coming off the top of the still. Basically you have a pot with a pipe pouring into it which in turn overflows into another pipe which carries the alcohol off to a receiver. The hydrometer floats in the little pot. These are usually inside an enclosed glass box or a box with a window so you don't have fumes all over the place, but allows you to look directly at the hydrometer to check the density. The hydrometers are relatively cheap, so you can buy several in case you drop one and break it, the rest is basically just made from pipe stock. Its about the cheapest way you can go.
Good Answers: 18
Re: density
12/13/2007 4:27 PM
In the distilleries that I have seen, the enclosed glass box is used to allow visual observation/measurement of the density of the alcohol stream from the top product which relates to the alcohol proof. These glass boxes are often sealed by the government to prevent tampering with the hydrometer (which I believe is calibrated by the governmental agency responsible for weights/measures relative to product quality). Taxes are assigned to the distillery based on the readings observed.
Technical Fields - Technical Writing - Validation Specialist-Medical Devices United States - Member - From the Big Apple! Hobbies - Model Rocketry - Rockets should go nuclear! Fans of Old Computers - PDP 11 - Studied computers at W.H.Taft H.S., Bronx, NY. Popular Science - Cosmology - Radio Science Observing
Re: density
12/15/2007 1:12 PM
...the density of WHAT?!
WARNING! All suggestions are informative only. It is the prerogative of the user to implement under his sole responsibility. This commentator will not be liable for any damages or injuries incurred.
agua_doc (1); Anonymous Poster (1); gigaconcept.com (1); healybj8 (1); ronald (1)
