Previous in Forum: Is this real?   Next in Forum: The Cavendish Experiment
Installing Pipe Liner
06/16/2023 1:58 PM
Re: Installing Pipe Liner
06/21/2023 9:03 AM
That pipe lining is going to save a ton of time and money!
MikeMack747
06/21/2023 11:17 AM
I did not know they could line pipes at that small diameter. It makes sense for long runs of pipe with no connections or branching. I work with lining storm and sanitary sewers every day. In the larger diameter pipes, we can send equipment down to cut holes for connections and branching. I am not sure if that is possible in the smaller diameter pipes. In other words, you better not need any connections that are existing, but they will be blocked.
06/24/2023 3:09 PM
Mo' better explanation....
Register to Reply 3 comments
ccoop609 (1); MikeMack747 (1); SolarEagle (1)
