Previous in Forum: Interesting Development in AI...Except for power in an emergency...   Next in Forum: Miracle House or is it Just Smart Planning
Gas Cylinders Inspection
08/20/2023 2:47 AM
Good day everyone,
As per the ISO-6406, the gas cylinders are subject to pressure test or ultrasonic test. the subject standard did say if the pressure test can be superseded in case the UT survey was carried out. so, can be the cylinders only UT scanned and be endorsed as the results of UT was satisfactory? anyone had experience with gas cylinders to get answer. we have difficulty in the pressure testing due the facility availability.
Best Regards,
Re: Gas Cylinders Inspection
08/20/2023 1:50 PM
I don't see a problem with ultrasonic testing vs pressure testing, generally speaking, there might be exceptions with certain types of gases and/or pressure levels though...
https://www.phtool.com/custom-reference-standards/pressurized-cylinder-standards/#:~:text=Ultrasound%20is%20a%20great%20alternative,during%20a%20standard%20hydrostatic%20test.
08/20/2023 11:24 PM
Given my druthers, I would rather have the hydrostatic test, because I think it would be more likely to find any problems. Ultrasonic would, I suspect, depend on the skill and thoroughness of the operator.
Lehman57
08/23/2023 7:30 AM
Here's another vote for that. GA.
Good Answers: 125
09/01/2023 2:37 PM
We work with gas cylinders frequently. They should be hydrostatically tested periodically in accordance with the standard that governs their use.
Register to Reply 4 comments
Lehman57 (1); PWSlack (1); SolarEagle (1); WJMFIRE (1)
