Previous in Forum: Shipping Container Sized SS Housing   Next in Forum: Plastering Drywall - Improvising Fill for a Gap
Plinth Beam
12/08/2023 9:09 AM
The compound wall on one side of our building collapsed and the plinth beam is slightly tilted what the structural consultant said.Is there any way to correct it back to original position
Re: Plinth Beam
12/08/2023 2:14 PM
A lot can be done with hydraulic jacks and a grout pump...but it depends on the situation, if the beam is tilted one way or the other or crumbling, might need complete replacement....
..."A plinth beam is a reinforced concrete beam that connects a wall to its foundation. When the foundation settles, a plinth beam is installed to prevent the expansion or propagation of cracks from the foundation into the wall above. Plinth beams equally distribute the wall's load across the foundation.
The Plinth Beam is an RCC Beam that connects the wall to the foundation. This prevents cracks from spreading from the foundation to the wall above, as well as spreading the wall load evenly throughout the foundation."...
https://www.linkedin.com/pulse/plinth-beam-its-purpose-qto-construction
https://www.alphafoundations.com/services/foundation-repair/problem-signs/foundation-settlement/
Re: Plinth Beam
12/12/2023 6:03 PM
CaptMoosie? Still lurking around out there in the ether? We miss hearing from you.
