Previous in Forum: Grid Connected System Still Importing Power from the Grid   Next in Forum: Persistent Sparking in Red Phase Electrode Chamber of LRS During Startup of a Newly Installed 3.4 MW, 6.3 KV Wound Rotor Induction Motor Driving a Vertical Mill
Vector Group of Transformer
05/05/2024 8:23 AM
Why are distribution transformers always Dyn11 connected? Why not Dyn1 or something else?
Re: Vector Group of Transformer
05/06/2024 8:15 AM
ChatGPT says this (I don't claim to understand a word of it!)
Distribution transformers are not always Dyn11 connected, but it's a common configuration for many reasons:
Reduced harmonics: The Dyn11 connection provides better mitigation of harmonics compared to other configurations. This is important in distribution systems where nonlinear loads such as computers and variable frequency drives are prevalent.
Lower zero-sequence impedance: Dyn11 connection offers a lower zero-sequence impedance compared to other configurations, which is beneficial in systems with unbalanced loads or in networks with high zero-sequence impedance.
Better phase angle control: Dyn11 configuration allows for better control over the phase angle between primary and secondary voltages, which is important for stability and efficiency in the distribution system.
Lower eddy current losses: This configuration reduces eddy current losses in the transformer windings, enhancing efficiency.
Common in Europe: In many European countries, the Dyn11 connection is standard or preferred due to its advantages in handling common distribution system challenges and its compatibility with local standards and regulations.
While Dyn11 is common, other configurations like Yyn0, Dzn0, etc., are also used depending on specific requirements and local standards.
05/06/2024 11:13 AM
Perhaps this will help:
1. What is the difference between Dyn11 and Dyn1 vector group in transformers? Dyn11 and Dyn1 are two commonly used vector groups in transformer configurations. The main difference between them is the phase shift between the primary and secondary voltages. Dyn11 has a phase shift of -30°, while Dyn1 has a phase shift of 0°. This means that the secondary voltage in Dyn11 is 30° behind the primary voltage, while in Dyn1, they are in phase.
2. How does the choice of vector group affect the transformer's performance? The vector group of a transformer is important because it determines the phase relationship between the primary and secondary voltages. This can affect the performance of the transformer in terms of its efficiency, voltage regulation, and fault tolerance. For example, Dyn11 transformers are more suitable for supplying non-linear loads, while Dyn1 transformers are better for linear loads.
3. Can a transformer's vector group be changed? No, the vector group of a transformer is determined by its design and cannot be changed. It is important to select the correct vector group for the intended application before purchasing a transformer. Attempting to change the vector group of a transformer can result in damage to the transformer and potential safety hazards.
4. What is the significance of the numbers in the Dyn11 and Dyn1 vector groups? The numbers in the Dyn11 and Dyn1 vector groups refer to the phase shift and connection configuration of the transformer. The first number (11 or 1) represents the phase shift, and the second number (1 or 0) indicates the connection type. In both vector groups, the second number is 1, indicating a delta connection on the secondary side.
5. Which vector group is more commonly used in industrial applications? Dyn11 is more commonly used in industrial applications because it is more suitable for supplying non-linear loads, which are common in industrial settings. The -30° phase shift in Dyn11 helps to reduce harmonics and improve the stability of the system. However, the choice of vector group ultimately depends on the specific requirements and load characteristics of the application."
Reference: https://www.physicsforums.com/threads/transformer-vector-group-dyn11-and-dyn1.497958/
Good Answers: 42
05/15/2024 12:56 PM
See IEC 60076-1-for instance.
Julius
Good Answers: 42
05/15/2024 1:31 PM
IEC 60076-1 Annex D I cannot attach the file sorry
Julius
Register to Reply 4 comments
7anoter4 (2); Randall (1); Rixter (1)
