Previous in Forum: Can Acrylonitrile Styrene Acrylate (ASA) be Chemically Bonded to s Dissimilar Plastic such as PVC or ABS?   Next in Forum: Type of Metal Rods/Wire to Use in Pottery Kiln
8 comments
Cast Iron Grade Identification from Spectroscopic Analysis
06/01/2024 5:49 AM
Can anyone shed some light on identification of a grade of cast iron based on the XRF Spectro shoot pictured ?
Cast Iron would usually be 2 - 4 % Carbon with Fe and other alloys in small concentrations.
78 % Zinc does not make sense and Cobalt shouldn't be anywhere in this sample ?
The test instrument is calibrated and tested other samples correctly prior to this one.
Testing on the other side of the component yielded a result of 84 % Zinc and 14 % Iron.
The component is part of a hydraulic cylinder.
Any metallurgists got ideas of whats going on here ?
Fe 21.19 %
Co 0.444 %
Cu 0.123 %
Zn 78.07 %
Re: Cast Iron Grade Identification from Spectroscopic Analysis
06/01/2024 8:48 AM
Maybe diecast Zinc rather than cast iron.
Some places simply used whatever was available for the melt.
Or else you're measuring a thick Zinc coating rather than the parent metal.
06/02/2024 5:24 AM
Correct , it was a very thin zinc plating , silly i overlooked that when "The evidence was right under my nose" .
actual Spectro of the cast iron is 97 % Fe , 1.4 % carbon , 0.44 % Cu , LEC remainder.
06/03/2024 10:04 AM
An iron alloy of carbon 2.1% or lower is defined as steel, not cast iron.
A small variation in percentage of carbon has a big impact on material property.
06/03/2024 10:15 AM
I did a test weld with MIG , welding a round bar to it with a fillet weld then tapped it with a hammer , the weld broke off the casting leaving a 0.5 mm indentation in the cast with no fusion , just as you get if trying to weld a gray cast iron.
The item has a fracture in it from impact , if it was steel it would deform rather than fracture.
06/03/2024 11:28 AM
Yes.
My point, reading again my comment in #5, wasn’t stated very clearly.
I do not doubt the characteristics of the subject material. The spectro analysis sample seems to have been contaminated, or compromised, or adulterated...
06/01/2024 9:49 AM
It looks like galvanized iron. Maybe the copper and cobalt are impurities from somewhere else.
06/01/2024 10:45 AM
"The component is part of a hydraulic cylinder."
I think you need to be more specific.
06/11/2024 7:15 AM
Yes. The original equipment manufacturer certainly can. That's what the telephone is for.
Register to Reply 8 comments
Doorman (2); Just an Engineer (1); Nothing is Impossible (2); PWSlack (1); Randall (1); Rixter (1)
