Previous in Forum: Strain Gauges in Truck Scales   Next in Forum: Water vs Wind Dynamics
8 comments
Testing a New UHDPE Netting
08/14/2024 9:06 AM
I've hung a single mesh of UHDPE netting on a pin. I have 30" of this netting attached to a 16 lb. weight. I swung the weight back and forth about 30-34" side to side. Question: Is there any way to determine the strain or Bollard Pull or weight exerted on that single mesh shown on the pin?
Re: Testing a New UHDPE Netting
08/14/2024 11:54 AM
Rule of thumb, a swinging weight will exert about 3 times it's dead weight in a pendulum swing...but I would be more concerned with abrasion in this example, I would let the weight swing on a pulley of some sort....
08/15/2024 12:55 AM
Something like this needs to be in the loop
08/15/2024 1:25 AM
The stress on the mesh is greatest at rest, ignoring the friction stress on the mesh on the pivot point. I'm not sure where the cited rule of thumb comes from, but doesn't appear to apply to this case. See this link https://www.physicsclassroom.com/class/waves/Lesson-0/Pendulum-Motion#:~:text=There%20are%20two%20dominant%20forces%20acting%20upon%20a,and%20towards%20the%20pivot%20point%20of%20the%20pendulum.
start here:
The gravity force is highly predictable; it is always in the same direction (down) and always of the same magnitude - mass*9.8 N/kg. The tension force is considerably less predictable. Both its direction and its magnitude change as the bob swings to and fro.
08/15/2024 7:05 AM
08/15/2024 10:50 PM
THIS is all I want to test. When will a mesh with NO TAG ENDS break?
08/16/2024 1:31 AM
You need to hook up one of these line breaking test assemblies....it will almost always break at the knot, so the tag doesn't really matter, as long as the knot holds securely and doesn't slip....
08/16/2024 8:20 AM
Thank you all as always for any and all information.
08/23/2024 7:58 PM
IMHO:
If the knot used does not slip,the breaking should be the same,and if it slips,of course,it will slip out rather than break unless you put a stop knot at the end of the tag ends.
Register to Reply 8 comments
HiTekRedNek (2); netmaker (2); rwilliams (1); silvCrow (1); SolarEagle (2)
