Previous in Forum: Testing a New UHDPE Netting   Next in Forum: WatchPower Password Reset
11 comments
Good Answers: 146
Water vs Wind Dynamics
08/16/2024 7:22 PM
Been pondering some of the mysteries of microclimate, and seeing that both water and wind are fluid dynamics I wondered if someone more versed in these matters would comment or discuss the differences between aerodynamics and hydrodynamics, whether they are simply parallel and equivalent or whether there is anything special that separates one from the other.
Not that they are ever really separate from one another in the real world. There's water in the air and air in the water.
Geographically, this mixture is flowing around the solid objects, hills mountains plains valleys in my environment, so I am wondering what differences there are in wind vs water. Water is affected by gravity of course. Obstacles will push it downward and to the side because of its weight. I guess I just don't know what happens with wind and how it may or may not be different in its dynamics.
incus opella
Re: water vs wind dynamics
08/16/2024 10:16 PM
I'm not very well versed in either of these topics but a big distinction is compressibility.
08/17/2024 7:59 AM
That’s true,
I had used CFD software to determine the efficient design for piping for cooling water piping as well as ducting for exhaust gases..
There are similarities for both, for the design, what I have found is there are at times where the similarities are nominal.
it all depends on the numbers and applications, such as volume (SCFM/ACFM for exhaust gases, GPM for fluids).
Good Answers: 146
08/17/2024 11:24 AM
Well my first thought was One Second Plumber, but beyond the can, this is actually part of the answer I was looking for. In microclimate, atmospheric subsidence.
"Atmospheric subsidence is the downward movement (sinking) of air parcels in the atmosphere. It is the opposite of atmospheric lift. This movement compresses the air, which increases both the temperature of an air mass and its capacity to hold water vapour. The net effect is a lowering of an air mass’s relative humidity, and the dissipation of clouds and precipitation. "
https://avalanche.ca/glossary
"Sinking air parcels warm via compression and spread outwards upon reaching the surface of the earth. Resultant weather typically consists of clear skies and light winds, though exceptions do occur."
So this explains why a foothill, surrounded more or less by larger hills at varying distances, is significantly dryer and hotter than microclimates even a few km away.
This might also explain why, even in cloudy weather, the sky commonly clears and sun shines at least briefly around solar noon.
incus opella
08/19/2024 10:53 AM
Because of the compressibility of air versus water as well as density of the matter, matters, such as supersonic speeds, are almost never dealt with in fluid dymnamics. Because of water's density, friction in water is so much greater. There are definitly many similarities, but the differences between in the phase of the matter (i.e. gas, liquid, solid) really does create significant differences that make comparison almost meaningless.
08/22/2024 4:32 AM
The other consideration is the ability to fill a container. The prefix <...hydro...> points towards liquid water, which will not completely fill any container unless sufficient is poured in; the prefix <...aero...> points towards air, which does actually fill any container it is presented with without more being introduced.
Such is the distinction between the liquid and the solid states of matter.
Good Answers: 146
08/22/2024 8:34 PM
When there's too much water for the container it overflows. When it overflows it strictly follows the path of least resistance, whether the flow is laminar or turbulent.
Water interacts differently with the ground as well. Water displaces air in soil, when there's too much of it or it can't drain through, water fills the pores that contained air.
Air can only displace water by causing it to transition to vapor.
incus opella
08/16/2024 10:31 PM
..."In physics, physical chemistry and engineering, fluid dynamics is a subdiscipline of fluid mechanics that describes the flow of fluids — liquids and gases. It has several subdisciplines, including aerodynamics (the study of air and other gases in motion) and hydrodynamics (the study of liquids in motion)."...
..."The difference is that aerodynamics does not care about the gravity effects most of the time but hydrodynamics usually accounts for gravity effects"...
Everything is set in motion by heat, as the air heats it expands, as do liquids, so you have the heating air and water expanding and the cooling air and water contracting, they are both subject to the coriolis effect and density that drives the denser air and water to the lower portions and the less dense air and water to the surface area....All these imbalances put everything in motion, creating weather together with the gravitational pull of the planets, chiefly the Moon, that creates gravitational pull that bulges everything out in that direction...In a nutshell...
Re: Water vs Wind Dynamics
08/17/2024 2:42 PM
One of the characteristics of fluid flow is the transition between laminar flow and turbulent flow. The ratio of inertial forces to viscous forces is the Reynolds number. Below 2300 the flow is likely to be smooth (laminar) and above 4000 likely to be turbulent.
"The Reynolds number is the ratio of inertial forces to viscous forces within a fluid that is subjected to relative internal movement due to different fluid velocities."
The Reynolds number is defined as:[4]
where:
https://en.wikipedia.org/wiki/Reynolds_number
In comparing two fluids under the same conditions, you would have to take into account the Reynolds number. Water has a higher dynamic viscosity than air, so you could expect different behavior.
https://www.princeton.edu/~asmits/Bicycle_web/transition.html#:~:text=The%20dynamic%20viscosity%20of%20water,keeping%20with%20our%20intuitive%20notion.
Good Answers: 146
08/17/2024 6:44 PM
Great link, Rixter.
So kinematic viscosity of water vapor is approximately the same as for air, and both are invariably turbulent. Phenomena like 'straight line winds' or 'gap winds' are more turbulent if anything, due to the higher speed.
Ended up reading this Nav Canada document as well, which goes into some detail about the effects of topography on wind.
https://www.navcanada.ca/en/lawm-atlantic-en.pdf
incus opella
08/20/2024 7:55 AM
I have not done the sums but the Reynold's numbers and hence flow characteristics for, say, wind and water turbines might be similar. I suspect that it is the density that would be the most significant parameter. Find a non-dimensional number combination that equates with power. Whether you use wind, wave or tidal power you are still getting the energy from the sun and by slowing the rotation of the earth. In the UK there may be a disastrous local effect like diverting the Gulf Stream more to the West of Ireland. I am too old to worry much about such things as this. Global warming and nuclear waste must be addressed rather than swept under the carpet by successive cash strapped governments.
08/20/2024 10:23 AM
imo, the Reynolds Numbers is a dimensionless, there may be a rule of thumb of the actually number, but it is basically subjective to the media that its being applied to.
Register to Reply 11 comments
artsmith (3); Brave Sir Robin (1); ccoop609 (1); John Hadland (1); phoenix911 (2); PWSlack (1); Rixter (1); SolarEagle (1)
