Previous in Forum: Local Control Station - Start Stop Remote   Next in Forum: Impact of Replacing a 37 kW Motor with a 45 kW Motor in a Deep Bore Well Pump Application
Simicode Relay New Version v3
10/25/2024 9:48 AM
Dear Team
found difficulty for parameter writing in simicode motor protection relay by using simicode ES application.
v1 v2 version was writing ok . now latest received v3 version getting difficulties.
kindly advice!
Re: Simocode Relay New Version v3
10/26/2024 4:03 AM
SIMOCODE ES is a software package that helps with the configuration, commissioning, operation, and diagnosis of SIMOCODE pro. It can be used as a standalone software or integrated with other TIA Portal V19-based software. SIMOCODE ES is used for a variety of applications, including:
  • Switching devices
  • Protection equipment
  • Load feeders and motor starters
  • Monitoring and control devices
  • Safety technology
  • Position and safety switches
  • Commanding and signaling devices
SIMOCODE ES offers two program versions:
  • SIMOCODE ES Basic: A free tool for commissioning or maintenance engineers
  • SIMOCODE ES Professional: A tool for engineering and configuring with a wider range of functions and an integrated graphics editor
SIMOCODE ES offers a number of features, including:
  • Easy parameterization: A graphics editor based on the Continuous Function Chart (CFC) can reduce engineering work and shorten startup times
  • Clear plant documentation: Graphic presentation can help with plant documentation
  • Detailed information: Detailed information can help maintenance personnel and shorten downtimes
  • Parameter changes: Parameter changes can be made during normal operation
  • Motor protection: Monitoring of electrical variables can help detect irregularities in operating behavior
https://support.industry.siemens.com/cs/document/109811683/simocode-es-v18-(tia-portal)?dti=0&lc=en-WW
Re: Simicode Relay New Version v3
10/26/2024 4:41 AM
Simocode ES is currently at version 19.
Not sure if there is a "relay" branch at a lower version level.
Either way Siemens support should be able to help.
If all else fails go back to V2 'til they sort out the problems.
11/20/2024 12:44 PM
the problem solved by using the simocode v19 pro trial or payed version we can modify the project suitable for the V3.0.0 version.
set the the comunication properly it will work.
thanks for your valid inputs in precious comments.!!
10/26/2024 4:46 AM
Plctalk.net is probably a better forum than here.
10/26/2024 5:57 AM
while i am using simocode ES platform it proVPN model i cant able to send all parameter to devoce.i willshare the error message soon.
dineshkozhipurath (2); Randall (2); SolarEagle (1)
