Previous in Forum: Bendablity of Metals   Next in Forum: Vorecon
What’s Your Biggest Frustration with Using Desktop Robotic Arms?
07/22/2025 6:06 AM
Hi all — I’m a robotics engineer working on the next generation of compact, desktop robotic arms. We’re currently in the early design phase and trying to build something that’s actually useful for engineers, educators, makers, and researchers — not just a flashy demo piece. One thing I’ve noticed in my own experience (and heard from others) is how often these arms get in their own way. Whether you’re in a factory, a lab, or a classroom, you’ve probably hit some frustrating roadblocks when trying to actually use one of these arms. Maybe it was:
  • The deployment process takes too much time
  • The system is too complex to operate without formal training
  • It often requires relying on third-party system integrators
I’d really love to hear your experience — what’s the #1 thing that’s driven you crazy when working with desktop robotic arms? Bonus points if you’ve had to rely heavily on a systems integrator just to get something simple running. We’re collecting feedback directly from users to help guide design priorities, especially around deployment time, ease of use, and independence from integrators. Thanks in advance — excited to learn from your stories.
Re: What’s Your Biggest Frustration with Using Desktop Robotic Arms?
07/22/2025 3:23 PM
I've never worked directly with desktop robotic arms, but I did contribute to the safety design of a much larger machine's installation. Paramount in that installation was ensuring nobody could ever get in the way of the range of motion the machine could achieve. What puzzled me at the time was why the arm could not detect contact or near contact with anything. In my opinion, any safety system attempting to prevent possible contact was far less safe than one that detects contact when it occurs. My idea was that a galvanically isolated from ground arm could now detect when it made contact with anything in contact with ground.
07/22/2025 4:16 PM
Very slow
07/25/2025 3:21 AM
I designed a small Production Line layout using a robot arm to apply Glue / Sealant to a Component, it worked between two human assembly workers in a secure cage, parts were loaded and unloaded outside the cage by using a rotating triangular carrier with three interchangable nests.
The ability to time the robot to the time of the assembly workers was a critical factor as we had various sized componts we needed to apply glue to with different assembly times and glue runs varying from 120mm to 870mm.
The programming of the robot was done by the robot supplier.
The ability to adjust the speed is a critical factor to be taken into account and, naturally the function the robot has to perform. My robot carried a Nozzle and Hose to supply a Sealant Adhesive to a clearly defined area.
Hope you find my experience helpful.
Register to Reply 3 comments
phoenix911 (1); redfred (1); The Wizard (1)
