If you want to swiftly convert MSG to VCF, use certain applications like DataVare MSG to VCF Converter. You don't need Outlook for this tool to work on its own. You can add a complete folder of MSG files and export them to VCF with only a few clicks, thanks to the bulk conversion option. The tool keeps track of phone numbers, emails, addresses, and pictures. It works with any version of Windows and makes sure that your data is always safe. After conversion, it's easy to import the VCF files into any contact management system or device. You can also convert 25 MSG files to VCF for free.
