Previous in Forum: UPS Autonomy   Next in Forum: After Replacing My Electricity Meter with a Smart Meter, I Feel My Electricity Bill has Increased Significantly. Is this a Common Phenomenon?
15 comments
Ex Rated Socket/Adapter
11/10/2025 4:39 AM
We have a requirement of 480V AC socket requirement to suit for north American equipments; however we only have IEC certified Ex rated sockets available, just providing ex rated adapter will make it work? Will there be any issues?
Re: Ex Rated Socket/Adapter
11/10/2025 6:44 PM
I dislike adapters because they add more failure points. I also dislike anyone unqualified modifying 480 V AC circuitry. The fact that you haven't given any critical details means you are not qualified to work on a 480V AC circuit. A properly sized and fabricated adapter can be safely done. However, it is just as easy, if not easier, to make a hazardous adapter.
11/11/2025 9:30 AM
I dislike reading disparaging comments based on assumptions. The fact that he did not provide you with any critical details has absolutely nothing to do with his qualification to work on a 480V AC circuit and you know this.
Is this an electrical engineering forum or a giant pi$$ing contest?
11/11/2025 11:05 AM
A qualified electrician or EE would not go to a public forum to ask such a question.
11/11/2025 11:46 AM
I'm not real sure why anyone would come here to ask anything with replies like that.
11/11/2025 5:25 PM
480V AC circuits are not anything an amateur should touch. 480V AC is a power distribution voltage (also known as switchgear), not an end-user voltage. The arc flash from one of these circuits is terrifying. Here is a slow-motion video of what happens when an arc flash occurs at the poor soul closing the circuit.
I hope my "rude" reply prevents any of these arc flashes from happening to anyone.
11/14/2025 9:52 AM
No, it is NOT an electrical engineering forum!
It is an ENGINEERING forum. A place where dumb questions are asked on a daily basis.
The answer that offended you was from a long time, highly respected, highly experienced engineer member.
He spoke truth.
11/14/2025 10:06 AM
Which is why all of the conversations here exist among 4 people. One guy who asks a question and three "long-time, highly respected, highly experienced" dudes who tell everyone they are dumb.
Super helpful!
11/14/2025 10:21 AM
You will go far here!
GOOD LUCK
11/14/2025 1:00 PM
You've been a member for 12 years, and 10% of your contributions are your complaints in this individual forum thread. You are not super helpful yourself.
11/10/2025 10:55 PM
If you can show the adapter meets all of the Ex requirements when used with your normal socket, as well as basic reliability specifications such as surge current and machinery vibration, it should be perfectly acceptable. A UL evaluation of the combination would be most compelling for the US purchaser.
There is, as mentioned, an additional failure risk with the introduction of another component, but that is probably well mitigated by the risk taken on by modifying your proven standard panel construction methods.
It appears that the buyer smartly wants to be able to locally source typical repair parts, your adapter will provide that capability.
12/12/2025 5:13 AM
@ Lyn, in reply to your comment in Answer #7, this is a ELECTRICAL ENGINEERING forum, which is separate from the other Engineering forums, Civil and Mechanical listed under CR4 Sections.
Also in my humble experience, there are no dumb questions, sometimes only dumb answers, which seems to be the case in this thread.
The original poster obviously not US based, was asking if there would be any issues using a Certified Adaptor (EX assuming Explosion proof) as they don't have original 480v US Sockets available.
To me, that was a perfectly normal question from an importer wishing to know if there are, for instance, Federal or local by-laws regarding the connection of a machine to a 480v power source that restricts the use of Adaptors.
I agree with Redfred's comment that Adaptors should be avoided if possible but I disagree with his assuption that the poster has no electrical knowledge.
What other critical information should the OP provide ? He asked a simple question,
"Can I use a IEC Ex Certified Adaptor in the USA to connect a machine to the US 480v power supply?"
He stated that his company does not have standard US Sockets available and purely wanted to know if he can use the specified Adaptor or not. If he had no electrical knowledge why would he be asking if he can use a specific Adaptor, especially one with an "Ex" rating, which implies a Safety Critical work area.
My advice, for what it's worth, is read the question posed and understand what is required for an answer, instead of going off on a "Off Topic" tangent that had nothing to do with the original request !
If the information in the original post is insufficient to give an informed answer then ask for more specific info.
Up to now I have only seen one answer to his question from rwilliams, the other answers did nothing to answer a simple request but to start a BS chain reaction of "who knows more than the other person ."
Reply Score 1 for Off Topic
12/12/2025 8:07 AM
Pardon me! I'll be sure to check with you before I post anything that might offend you.
12/12/2025 8:56 AM
Lyn, my post was not because you offended me, it was purely to point out your comment was actually wrong.
You posted "No, it is NOT an electrical engineering forum!
It is an ENGINEERING forum. A place where dumb questions are asked on a daily basis.".
If you check to the right of your screen you will clearly see on the 7th. line down of the CR4 Sections Electrical Engineering.
The OP did not ask a dumb question, even I ,as a non-electrical engineer, could see what he was asking for,a simple straightforward question.
"Can I use a IEC Ex Certified Adaptor in the USA to connect my machine to the US 480v system?"
A civilised answer could have been Yes it's not a problem" or You need to check with the local Authorities / Electricity Supply Company etc." where the machine will be used.
For example "In a meeting, an expert electrical engineer asks the buyer / project manager etc. can you check if we can use this product / part ?"
I worked for a company that manufactures Hi-tech machines and I could have asked that question without being an "electrical engineer" as a technical buyer for example or in my position as a Cost Engineer, to see if the Adaptor would be cheaper than purchasing the standard US Socket and changing the standard assembly process.
The fact that you seem to have been offended by my comments, appears to show you have a very short fuse ! No Pun intended.
The Forums here are for everybody to use but based on courtesy and fairness and respect for each other.
12/25/2025 11:13 AM
It is worrying that there is, apparently, no-one at the <...We...> that can answer the question.
12/26/2025 10:53 AM
That is precisely why I replied with a disuading answer.
Reply to Forum Thread 15 comments
dougefresh (3); lyn (3); PWSlack (1); redfred (5); rwilliams (1); The Wizard (2)
