Previous in Forum: What to do if the Steel Mesh Welding is Uneven or There are Missed Welds?   Next in Forum: Reinforcing Mesh Insufficient Weld Strength or Excessive Weld Penetration
H2O Pump Troubleshooting
11/22/2025 3:05 AM
Hi I am Taif ( Mechanical graduate engineer)
I am performing a troubleshooting for an overhung type pump (water booster pumps), 3 pumps in parallel two running and one standby lets name them (A, B ,C)
Data Sheet Data:
pump A is old and attached to low energy motor (voltage = 415v, current = 293A at 100% load, motor power= 180KW ) , rated capacity = 187.5 m3/h, Differential head= 170.5 m, speed=2980 rpm
pump B & C are new with high energy pump for each (V= 6.6Kv, I= 18.6 A at 100% load, motor power= 180Kw), rated capacity =187.5 m3/h, Differential head= 170.5 m, speed= 2975 rpm
The water goes from surge tanks to those water boosters then to water injection pumps
pump A is facing an excessive vibration with mechanical seal leak and the lock nut of the impeller keeps breaking everytime it fails, we are suspecting a high back pressure, the problem is that I don't have the disharge head or pressure to validate this assumption but I found
Calculated or actual data:
for pump B the actual head is 213 m at flow rate of 175 m3/h, but from manual pump performance curve (at flow of 175 m3/h, H= 163.2m)
for pump A the actual head is 213 m(assumed to be like B because of common head in parallel) at flow rate of 128.3 m3/h, but from manual pump performance curve (at flow of 128.3 m3/h, H= 190m)
this shows an estimation that both pumps are operating at higher heads than their predicts points to a system restriction.
What do you think ? what else I should do to look into all perspectives ?
Re: H2O Pump Troubleshooting
11/23/2025 1:18 AM
Sorry I meant OH2 overhung type
11/23/2025 10:56 PM
Can you confirm check valves are at each pump discharge, and that the valve internals are intact?
Vibration in one pump essentially identical to the others would appear to be a problem in the one pump. Consider misalignment of driver motor, or thrust bearing failure. If there is flow backwards, this might cause the impeller to unscrew. Breaking of the impeller nut is most puzzling.
This sort of hydraulic arrangement is not unusual and rarely leads to problems.
The difference of the motors appears to be inconsequential, on the surface. It would be rare to get a perfect match of slip on two even identical motors.
Can you measure flow under the 3 possible operating modes?
Measure the motor amperes under the 3 operating modes?
08/25/2026 12:46 PM
Two running, one standby. Please elaborate this:
1. Is pump changeover manual or auto?
2. B and C being new is there a tendency to keep them running and keep A as standby?
3. Watch pump A's NRV for backflow. If so, it is possible the pump runs in reverse. Depending on reverse speed the lock nut could get loosened. While so, if the pump is started by auto or manually, for sure the impeller would get knocked down.
4. Can you take solo run of A, if yes, many bad actors' (Alignment, Axial jog, Cavitation) dance can be filtered.
Please give more information to fix the issue.
09/10/2026 6:35 AM
Running three centrifugal pumps in parallel does not result in three times the flow as one pump, as the operating point moves to a different place on the downstream system pressure/flow characteristic curve compared to one pump or to two pumps.
If the output head of pumps B and/or C exceeds the head for pump A then in the case of a non-return valve letting by the flow through pump A will be sdrawkcab and flowrate to the destination will be lower than expected.
If this is the case and the non-return valve is okay then there is no point in running pump A with the other two.
Always install a pressure gauge downstream of pumps so that one can see what is going on!
Register to Reply 4 comments
PWSlack (1); rwilliams (1); taif (1); yesyen (1)
