Previous in Forum: H2O Pump Troubleshooting   Next in Forum: Wire Mesh Welding Machine
Reinforcing Mesh Insufficient Weld Strength or Excessive Weld Penetration
11/22/2025 7:54 AM
When the welding machine exhibits the above problems, the possible causes are as follows:
1. Weak weld joint: Welding current too low, or welding time too short.
2. Excessive weld penetration: Welding current too high, or electrode pressure insufficient.
3. Unstable weld joint quality: Severely worn electrode tips or an inefficient cooling system.
Knowing the cause, how can it be resolved?
Re: Reinforcing mesh Insufficient weld strength or excessive weld penetration
11/22/2025 7:57 AM
Check the current and time: Ensure that the welding parameters you are using match the wire diameter and material. Fine-tune the current (amperage) and welding time (time) accordingly.
Re-grind or replace electrode tips: Check the electrode tips for dents or oxidation. If worn, immediately re-grind them using a dedicated grinding tool to ensure a smooth contact surface.
Cooling system: Ensure sufficient cooling water flow and that the water temperature is within the normal range. Overheated electrodes will severely degrade weld joint quality.
