Previous in Forum: Before Synchronization — Generator Mode   Next in Forum: Magnet Coil and Closing Coil in Vacuum Contactor?
Low Voltage Switchboards
12/09/2025 12:05 AM
Why some vendors provide CTs at the load side of the breaker of the incoming panel and some vendor at the line side of the breaker of the incoming panel? what is the difference; does it have cost impact for the vendors?
Pathfinder Tags: CTs Line side Load side
Re: Low Voltage Switchboards
12/09/2025 10:49 PM
In the olden days, locating the CTs on the load side of the breaker would allow you to access the CT connections with less risk of electrocution, with the breaker open.
In other cases, CTs on the line side can be used for bus differential protection schemes, where the differential zone includes the circuit breaker, providing extra protection in the case of a fault within the breaker casing.
In a switchboard, it is most likely finding space to mount the CT, a matter of economics in layout and equipment construction. If just simple overcurrent and metering, it most probably is cheaper to put them where they end up. Conventionally, they are mounted on the load side of a breaker, where safety ground clamps can ensure that there is no primary current if the CTs have to have their secondary windings open circuited.
06/16/2026 7:57 AM
Low Voltage Switchboards are essential for safe and efficient power distribution in commercial and industrial facilities. Proper design, protection coordination, and regular maintenance help improve system reliability and reduce downtime. At VSS POWER, we have found that thorough testing and commissioning of LV switchboards play a critical role in ensuring long-term operational performance and electrical safety.
Register to Reply 2 comments
