Previous in Forum: Request for Availability – Control Board 8EL950009 A2 / Ref. ET000454 (Liftech)   Next in Forum: AHU Standard
The Ultimate Guide to Choosing the Right Wire Diameter for Your Mesh Machine
12/11/2025 6:20 AM
The intended use of the final welded mesh product is the most powerful filter for determining the right wire diameter. RKM Machinery produces specialized automatic wire mesh welding machines for various market segments, each requiring a specific range of wire thicknesses.
A. Heavy-Duty Applications: Reinforcement and Infrastructure (5mm — 12mm)
For projects demanding maximum structural strength, such as high-rise building slabs, bridge decks, mine support, and heavy-duty industrial flooring, the wire diameter must be substantial.
Typical Wire Diameter: 5mm to 12mm (e.g., RKM rebar mesh welding machine can weld 5–12mm rebar).
Key Machine Requirement: High transformer capacity, robust European welding technology, and a stable, powerful current output to ensure strong, complete welds on thick steel bar. The RKM-GW-3000B series is engineered specifically for this demanding range.
B. Medium-Duty Applications: Security and General Fencing (3mm — 6mm)
General security fencing, perimeter protection, construction wall insulation mesh, and industrial guarding require a balance of strength, cost-efficiency, and flexibility.
Typical Wire Diameter: 3mm to 6mm.
Key Machine Requirement: High-speed operation and high flexibility for various mesh sizes. Machines like the RKM Fence Mesh Welder are designed for rapid, precise production in this range, often producing both mesh panels and rolls.
C. Light-Duty Applications: Fine Mesh and Rolls (0.4mm — 3mm)
Applications like animal cages, agricultural mesh, fine sieving, decorative wall mesh, and some rolled wire products utilize smaller wire diameters.
Typical Wire Diameter: 0.4mm to 3mm (e.g., RKM’s electric welded wire mesh machine can weld 0.4–2.8mm low-carbon steel wire).
Key Machine Requirement: Emphasis shifts from raw power to high-frequency operation and continuous output to prioritize speed. The machine must handle light wire materials (galvanized, black wire, stainless steel) with precision. The RKM DP-DNW machine, for instance, focuses on efficient, precise welding of low-carbon steel wire.
Re: The Ultimate Guide to Choosing the Right Wire Diameter for Your Mesh Machine
09/10/2026 4:29 PM
Er, so is there a question for the forum?
