Previous in Forum: Heat Transfer   Next in Forum: Ultra Cleaning And Not Permeable Films To Organic Contamination
12 comments
Gum Stickiness In Gum Line Dies
12/12/2007 3:18 AM
We are making gum in factory. The kitchen, forming line are from Gabbler and executive. We are having a typical problem of gum sticking in dies and line is to be stopped every day for changing of die.
As a cost saving measure we have replaced "Trenwax" oil with Talc powder. It is creating a mess and also bearings need to be replaced frequently.
I need a help in following
1) Possible solution remove stickiness in dies so that die run continuously.
2) Any alternative to ' Trenwax' which is cost effective without compromising the quality.
3) Any possible alterative to "talc powder' which is used extensively. ( If used less creates stickiness).
4) Also need to understand the implication of "static voltage' could be the reason for sticking of gum to conveying belt which is nylon coated.
5) Any specific suggestions on recipie and relative proportion of glucose, sugar and gums.
Any help is appreciated.
Shivaram
+91-80-9845756340
Best Regards, Shivaram
Pathfinder Tags: gum stickiness talc
Re: Gum Stickiness In Gum Line Dies
12/12/2007 10:25 PM
Dear sir...
im not sure its possible or not...if u can use mold realesed agent..generally this agent used during compression molding.
12/12/2007 11:56 PM
If the address and contact number for procurement is given. Need to be food garde and to be suggetsed point of use with dosage.
Shivaram
+91-80-9845756340
12/13/2007 12:23 AM
harking back to the olden days of candy making food grade starch, chemical formula (C6H10O5) is a mixture of amylose and amylopectin (usually in 20:80 or 30:70 ratios). These are both complex carbohydrate polymers of glucose (chemical formula of glucose C6H12O6), making starch a glucose polymer as well, as seen by the chemical formula for starch, regardless of the ratio of amylose:amylopectin. Allows for fast easy forming of molds quick release of the item in the mold and is reusable
joshua
Technical Fields - Technical Writing - Validation Specialist-Medical Devices United States - Member - From the Big Apple! Hobbies - Model Rocketry - Rockets should go nuclear! Fans of Old Computers - PDP 11 - Studied computers at W.H.Taft H.S., Bronx, NY. Popular Science - Cosmology - Radio Science Observing
12/13/2007 10:47 AM
Consider these factors:
1. Has the process changed in any way since the last good-run?
2. Have you done Q-checks on the raw mat.?
3. Does the supplier specify storing/handling/manufact/shop-floor temperatures ?
4. Is RH% a contributing factor?
Try some dry runs and monitor, monitor, monitor!
WARNING! All suggestions are informative only. It is the prerogative of the user to implement under his sole responsibility. This commentator will not be liable for any damages or injuries incurred.
12/13/2007 11:47 AM
Besides the three ingredients you mentioned powdered dextrose is added also. the consistency should be that of bread dough. I saw this on an episode of "How's It Made" on the Discovery channel. They show all the ingredients being added but do not give proportions.
Chazl
12/13/2007 3:16 PM
I bet you could reduce the stickyness factor if you cut your gum pieces at a colder temperature. Whenever I leave gum outside in my car (cold weather) it will fracture when bitten instead of squish apart like warm gum. Think of the extremes: If you warm the gum prior to cutting, it will be very sticky. Freeze the gum, and it will fracture. Find a happy medium, and you might be worry free.
Once everyone is super, no one will be. - "Incrediboy"
12/13/2007 3:53 PM
Good answer; You beat me to it. I was going to suggest perforating the jaws and adding a circulating/cooling system to the jaws/dies. We did that succesfully at BSci Miami.
12/18/2007 4:09 AM
Since this is a design feature and we cant do much about it. ANy ideas to add/ dose oil/ die relaesing agent as against talc powder is welcome
12/18/2007 7:05 PM
Have you tried Sugarless? Try using substances with little or no sugar added!
12/18/2007 11:31 PM
Since sugar and glucos are part of recipie of the product, we cant do much about it.
12/19/2007 9:06 AM
Try lowering the gum temperature prior to entering the die - or lower the die temperature
12/19/2007 9:29 AM
Will you attach a drawing or JPG of the set-up so that we can see the process and /or the die section?
Register to Reply 12 comments
Anonymous Poster (1); Chazl (1); mutantone (1); ronald (4); shivaganti (3); SmithsEng (2)
