Previous in Forum: Optimizing Industrial Water Systems: When to Use HEDP or ATMP   Next in Forum: Pursuit Industries – Water Treatment Chemicals, Industrial Chemicals & FIBC Supplier India
What Tool Can Help with Bearing Interchange for Discontinued Parts?
01/18/2026 10:40 AM
You should use a bearing cross-reference system. It helps match old bearing part numbers with new or equivalent options from other manufacturers.
Pathfinder Tags: bearings
Re: What Tool Can Help with Bearing Interchange for Discontinued Parts?
01/19/2026 6:21 AM
Hello Poster, is there such a tool existing ? If yes why didn't you post a link instead of simply saying you should use a "bearing cross-reference system" !
Most people would simply enter the original part number in google / Bing and see what turns up or enter the dimensions of the bearing.
