Previous in Forum: 10,000 Year Memory Storage   Next in Forum: Has Anyone Used Keyence SJ-F700 Static Eliminator on Laminator Machines?
Is the Electron Made of Folded Light (Gamma Rays)?
02/22/2026 11:14 AM
This is very thought provoking..
https://youtu.be/hYyrgDEJLOA
Re: Is the Electron Made of Folded Light (Gamma Rays)?
02/22/2026 11:44 PM
The model I use, fits a round peg into a square hole. And fits perfectly, every-time.
The peg is matter and square hole is space.
My model doesn’t have a name, but it’s roots are Ampere, and Parsons. This was before the neutron was discovered, but it actually helps confirm the model.
My model shows the physical structure and motion for every property, and why and how that property and structure….. changes….. with energy
And bonding structures. And the true concept of mass. And absorption.
All this is eye opening and explains so much.
But the greatest surprise was emission.
Emission is very unique. Asymmetrical. And explains why cosmology is such a puzzle.
02/24/2026 8:26 AM
Yes it is thought provoking. Turns Electrons making light on its head.
My own take is that the use of the word Vacuum is misleading.
The creation of the electrons and positrons in themselves created the energy 'electronic field' that extends through space, as before there would have been infinite space filled with zero energy.
This treatment of the electrons as toroids needs a thorough think through but appears to explain what charge is and where the magnetic moment comes from. It reinforces the notion that it is the electrons that cause magnetic fields, especially when they are confined in magnetic materials and not just producing magnetism by virtue of their motion.
What I would like to know is the origin of quarks and how electrons captured them in order to form the Hydrogen that dominates in our universe. This would back up the notion that it is the vast bulking together of electrons that distort the 'electronic field' and which we recognise as gravity.
duikerbok
02/24/2026 12:33 PM
Indeed interesting/thought provoking! I'm not sure whether it was the audio, the accent, or something more related to my hearing, but I had considerable difficulty understanding the speaker. Fortunately, the graphics conveyed most of the message.
Thanks for sharing!
02/25/2026 5:10 PM
I have a delusion. I believe that the structure, dynamic and description of light is all wrong.
I believe that all EM radiation is singular. A singular solitary isolated event. Radio is just a timed sequence of this dynamic.
Sound has a full period of acceleration to leave the source. It has a full period of propagation flyby duration. And it has a full period for detection, to record the disturbance. All three dynamics have the same time duration.
EM radiation, which I will refer to as light, has a 0 acceleration time. The field that is about to be emitted, is already at velocity, it does not need to be accelerated. It’s at speed, in an angular velocity.
The act of emission, is an instant breakage from that spin. It’s like spokes on a spinning hub. Emission is when the spokes are released. The spokes change direction. And the spokes always keep their length. Unlike spokes, EM has no inertia, and can make instant 90 degree turns. Like a reflection can.
The propagation flyby duration is 1/2 period. ½ wavelength. It’s a constant length chunk. NOT a stream.
IF there is no relative motion, the duty cycle from a radio link, will be 50%.
For instance, a 300 MHz carrier has a photon length and duration of ½ wavelength(.5meter) and ½ period. And a ½ period of dead space between every photon. It blinks. 50%.
Detection has a period of …. one full period. The photon distorts the detector matter field. This photon field has momentum and the matter fields have inertia. The photon accelerates and distorts the matter field and the matter field answers with the equal and opposite reaction.
This gives ½ period to stimulus and ½ period of reaction…… resulting in one full period of detection. A frequency.
This is what happens with a single radio source. Lets add a little motion. Have you ever baled hay? Have you seen a baled hayfield?
The baler(emitter), always drops the same length bale(photon chunk). The speed of the baler…. ONLY change the space length between bales. This sets the ratio of photon length… to photon space length. The ratio of the emitted duty cycle. Due to baler(emitter) speed.
Now the hay trailer(detector) that picks up the bales……. it’s speed…..ONLY changes the RATE of that emitted ratio. This will be the pattern that disturbs the matter field. Detection.
Again….. this is for sequential radio. We can adjust and set the energy and timing of radio photons.
BUT we can not change the energy or timing of light photons. The only way to increase the energy of light…. Is to add more emitters…. For more photons at the same time.
A flux of photons. We need many many photons to see and measure light photons. The light emitters are not stationary. They move and turn between emissions. That changes alignment and intensity.
A radio is like a dripping faucet. Light is like a steady rain shower.
AND to make it even worse, photons superposition. That superposition shower….. is what we detect.
Out of our large spectrum of the sun, how many frequencies are truly emitted? And how many frequencies are superposition. How many frequencies does the periodic table emit?
Feed a Marconi antenna with a fully rectified carrier….. at feedpoint(no transmission line).
And see for yourself. I said rectified, not filtered. At the end of every 180 degree input, one photon is instantly emitted. It snaps. A quick squeak. A blink.
It instantly collapses out….. into space. An unhearable, un-seeable, instant space spark.
Our first antennas were intermittently fed. They are just fed a little smoother today. But still half wave chunks are emitted from it.
I will take my medication now.
Register to Reply 4 comments
dkwarner (1); duikerbok (1); Haymaker (2)
