Previous in Forum: Limiting Cable Temperature   Next in Forum: Black Star Diesel Generator
Regavolt Variable Transformer Current
03/11/2026 10:06 AM
Hi,
I have a labelled as LD-173. I want to know what the current rating is. Based on the wire thickness, it is about 25Amp, however, as I cannot find reference to the exact code, only a series, but not sure what series it would be in. The wire measures 3.31mm, obviously that includes insulation. So, does anyone out there know what the current rating is please?
Re: Regavolt Variable Transformer Current
03/11/2026 5:38 PM
From here in the USA, my searches for anything referenced as exactly LD-173 comes up empty.
Here is a link to a published history of Regavolt Variacs. I don’t see anything there that offers any near matches to that number.
https://www.claudelyons.com/resource-centre/a-time-line-of-the-variable-transformer-1933-present-day/
Can you toss us a meatier bone here? Approx age, weight, dimensions… how about a picture or two, maybe a pic of the nameplate?
03/12/2026 5:59 AM
Hi,
Sorry, but couldn't upload a picture. It is 32cm in diameter, approximately 10cm high (the winding) and weighs 78 pounds. Not sure of the age.
03/11/2026 11:03 PM
Assuming 600 volt insulation, that would be about #12 AWG, probably good for 20-25 amperes in open air, as you postulated.
03/12/2026 5:56 AM
Thanks for the input. I will go with that value.
03/12/2026 6:36 AM
I found this on a search "The first models were rated at some 500 VA (200 series) , and were followed a year or two later by larger units rated at about 2 kVA (100 series), and subsequently 5 kVA (50 series)."
Maybe your LD-173 puts it in the 100 series and if so it approx 8 amp however 3mm dia puts it at 25 amp. A bit of an anomaly unless the limitation is the brush current carrying capacity.
Hare today, goon tomorrow!
03/25/2026 10:01 AM
Treat it as an ~8 A device, not a 25 A one. Your “anomaly” is real—but it’s explained by system-level limitations rather than the wire itself.
DiegoLopez (1); Doorman (1); rwilliams (1); Stef (1); TeslaDog (2)
