Previous in Forum: Ancient Maps   Next in Forum: Tommey Reed Richard Clem Engine Update
What Really Defines a “Good” Resistor in Precision Current Sensing Applications?
03/23/2026 4:01 AM
When we talk about a “good” resistor, most of us probably start with tolerance and power rating.
But in real current sensing designs, especially at higher currents, I’ve found those specs don’t always tell the whole story.
For example:
  • A low tolerance part can still drift under load if the TCR isn’t well controlled.
  • Thermal gradients across the resistor body can shift readings more than expected.
  • Long-term stability under continuous current stress sometimes matters more than initial accuracy.
  • At low current ranges, even small thermal EMF effects can start to show up.
On paper, many parts look perfectly fine. In actual hardware, the behavior can be quite different once temperature rise and layout effects come into play.
So I’m curious how others approach this:
  • When selecting resistors for precision current sensing, what’s your top priority?
  • Do you focus more on TCR, construction type, or long-term drift?
  • Have you ever had a “good spec” resistor that didn’t behave well in the real system?
Interested to hear real-world experiences from others working on similar designs.
Re: What Really Defines a “Good” Resistor in Precision Current Sensing Applications?
03/24/2026 1:56 PM
Hi Resi, Welcome to CR4.
I'm retired, but worked for a Standards Laboratory many years. We would use commercially made current shunts, some of which are not expensive. They have a current rating so you know what to pick. The output voltage can be chosen to best suit your needs (0.1V, 0.05V, etc). Otherwise the Temperature Coefficient (TC) was the most important to me (TCR to you?). Shunts were calibrated, so the value was not important. Hope this helps.
06/15/2026 9:38 AM
You could take three measurements. Measure the resistor value, measure the current (via voltage drop), then measure the resistor value again and average with the first resistance value.
MikeMack747
06/15/2026 5:29 PM
What is a good resistor, quality, tolerance, stability, suitability.
Test the resistor value with a Wheatstone bridge if an accurate value is needed. A high precision multimeter or ohms meter is best to check measured value against indicated value to check the tolerance of the DUT.
Choose the right type of resistor for the use, DC, AC low frequency or high frequency, no inductive, wire wound, high current etc.
If temperature drift is a concern, then while testing the resistor raise the temperature with a hot air gun and then freeze the resistor with a cooling solution and log the variation.
I used to work in an instrument repair and calibration section and often performed these tests to maintain accuracy of repaired instruments.
Hare today, goon tomorrow!
06/17/2026 4:25 PM
A cynic would say a good resistor is one that retains the smoke as well as its value!
Register to Reply 4 comments
MikeMack747 (1); StandardsGuy (1); Stef (2)
